Curtains!! The real story behind this little bit of sharing. I know that there are many good ways to block incoming
light. I've seen them actually in hindsight via the forums--after I made our
Casita curtains. My curtains have worked smoothly and effectively for two years now so I felt someone out there might benefit and like the way I did them.
Some people hate the mini-blinds and have taken them out completely. I understand this, but we have come to like the ability to let a little
light in, direct the
light in a particular direction, or just being able to peek out. But, when closed, they don't cut out enough light to my satisfaction and don't give me a complete privacy feeling when they are closed. So the idea of curtains-blind combination is great.
Plus, our little dog we adopted from an animal rescue with separation anxiety, who is actually now much more calm, but still gets quite anxious and will claw at the window trying to tell us that she doesn't want to be left alone, when we're doing just that--leaving her alone. So, in my design, I needed curtains that were split, so I could drop the side covering the screen part of the window (thus saving the screen) and leaving the glass side exposed so she can see out.
We added an extension to the aluminum L-shaped support. The extension is attached to a wooden rod which runs through the curtain.
I measured
windows and sewed the hems. The top hem was large enough to run a wood rod through. The bottom hem would accommodate a light PVC pipe. The PVC pipe would add enough
weight to unroll the curtains as later shown. I purchased a used dark blue sheet from Savers (my hubby previously stated we're cheap, but a sheet is a lot of material) then sewed the darker material on what would be street side. We then ran pole through the top hem of the curtains. The pole is then connected to the metal extension. We also attached a nylon cord to the attachment (again this is street side).
Once attached to the extension, we screwed in two eye screws in the front of the rod to run the cord through.
I added loops on the cord that hook on the 'famous' drapery slip-on hooks (we Casita-ians use to hang things on the carpet lining our
fiberglass walls) to keep the curtain from flopping when let down. I can also pull it taut after hooked.
I've included additional photos and a video on my travel blog that shows how nice they roll up or down.
I did all this right after our purchase. Inside, it's been dark enough for the brightest of campgrounds. We're ready for the night of the midnight sun!
Please note, I post to multiple forums. Some people only belong to one forum and others belong to more forums than I do. I'm just sharing.
