Load Range D Tires on Scamps - Fiberglass RV
Old 04-12-2017, 08:32 AM   #1
Trailer: 16' Standard
Ohio
I'm due for new tires and would like to hear from anyone who has put them on their 16' Scamp in particular, or other models. How to the feel, are they bumpy, due the side wall get hot? Any feedback would be appreciated.
Kenny in Ohio is offline   Reply With Quote
Old 04-12-2017, 09:41 AM   #2
NW Wisconsin
I had D Rated tires on my 16 ft Scamp Std and have D Rated tires on my 17 ft Casita SD . ( Inflated to 60 to 65 PSI ) . I have not encountered any problems. I am more concerned with weight rating than a bumpy ride . You can run the tires at a lower pressure to soften the ride but I follow the advice from Discount Tire and run the tires at their full rated cold pressure.
Old 04-12-2017, 10:33 AM   #3
rdickens's Avatar
Trailer: 2017 Scamp 16 Deluxe
Missouri
I had posted this a couple of months ago.
http://www.fiberglassrv.com/forums/f...res-78639.html
Ours seem fine.
No hot sidewalls and less bouncy/bumpy than our previous Scamp13.
Ray
rdickens is offline   Reply With Quote
Old 04-12-2017, 02:14 PM   #4
Ohio
Thanks Ray
I just read it. I will change to the D range now. I have always tried to make improvements to various things along the way and somethings I had been sorry for changing.
KVJ
Old 04-12-2017, 03:55 PM   #5
rdickens's Avatar
Missouri
No problem, Kenny!
Glad to help when I can.
In post 38 of that thread, I put in a link to the Carlisle D rated tires:
..... link to the Carlisle D load range tire that might be the better option for a Scamp16?
ST175 /80 R13 96M D1 BSB
http://www.discounttire.com/en/buy-t...ail-hd/p/27240
Ray
Old 04-12-2017, 06:06 PM   #6
Ohio
Again
Again thanks. I will talk to my local tire shop first. DT tire shop is an hour or more away.
Old 04-12-2017, 06:51 PM   #7
Joe & Cherie's Avatar
Trailer: 2013 EggCamper & 2011 Silverado Reg Cab 4x4
Ohio
Hi Kenny,
I put D on my EggCamper and although I dont have miles on it, I think it was the best way to go vs C. I also ran D on a Casita for 2 years - it rode great! I ordered the Maxxis M8008 off Amazon. When they come in I checked the tire date and they were only 3rd week of 2017 (0317).
2013 EggCamper #120
Joe's EggCamper Journal
Joe & Cherie is offline   Reply With Quote
Old 04-12-2017, 08:06 PM   #8
Ohio
That was my next thought, when I go to the tire shop and ask for current tires.
Off Amazon no less, good for you. I live under Murphy's Law, if I were to order on Amazon I would get tires with the same date I already have.
Anyways...Thanks everyone!
KVJ
Old 04-12-2017, 09:38 PM   #9
Trailer: Trail Cruiser
The heavier the better!
Mike_L is offline   Reply With Quote
Old 04-13-2017, 07:39 AM   #10
Ohio
KVJ
ha! I know the feeling. The seller was called "Award Products". Weird name I know for tires..... They shipped out of a warehouse in Pennsylvania. I know nothing about them except my experience with that one order. Good luck!
2013 EggCamper #120
Old 04-15-2017, 03:45 PM   #11
Ohio
On today
I had the load range D tires mounted and balanced today. I got the Carlisle HD
and the DOT date is 0417.
Old 04-15-2017, 04:19 PM   #12
Add a TPMS and you are DONE!
(Assuming that if it is valve mounted, you have metal valve stems)
Old 04-15-2017, 07:23 PM   #13
All tires should be balanced
Old 04-15-2017, 07:39 PM   #14
As also should be the driver of the tow vehicle.. even though that is often not the way it works out.
scamp, tires
New tires for 13' scamp- load rating? chse Problem Solving | Owners Helping Owners 2 04-25-2013 04:48 PM
Load Range D Carlisle Tires Pete Dumbleton Care and Feeding of Molded Fiberglass Trailers 11 09-27-2007 05:51 AM
milliamps and testing battery load David Scott Problem Solving | Owners Helping Owners 7 05-23-2007 01:20 PM
Load sensing generators ewilkie Problem Solving | Owners Helping Owners 1 04-25-2007 06:42 PM
