Top Seam on 1998 Burro - Fiberglass RV
Old 04-03-2017, 03:48 PM   #1
Trailer: Burro
Utah
While I was on the roof of my Burro I noticed that the seam on the top looks like it's separating. I've attached some pictures but I don't know if they are really that great to see what's going on or not.
Anyway, if the seam is separating what do I need to do to seal it back up? I have had the trailer covered all winter, I live in Utah so it was subjected to some freezing temperatures over the winter.
Cynthia
Cynthiablue is offline   Reply With Quote
Old 04-03-2017, 05:30 PM   #2
Picture isn't clear enough, but what you are seeing could be the trim piece that goes over the shell seam. It pushes on over the seam.
Old 04-03-2017, 06:17 PM   #3
Trailer: Burro
Utah
Ah ok... can it be replaced? Does it need to be replaced? That is probably what it is. Yeah sorry for the poor pictures.
Old 04-03-2017, 06:41 PM   #4
Do a search for Trim-lok. They call it edge trim. You'll have to figure the size as far as width goes. Available in a couple colors and from various places. It can be replaced. Yours may have metal in it that has deteriorated causing it to come loose. May be a little tricky if it curves down the front and rear, which I assume it does, same as our Uhaul. You may have to temporary clamp it in position or use a adhesive under it like Proflex. And for your roof vent you may have to replace the whole unit if a cover can't be found.
burro
Vertical Seam Versus Horizontal Seam Cathy P. Care and Feeding of Molded Fiberglass Trailers 17 03-17-2015 11:25 AM
Top Roof Seam on 13 foot Burro John Colangelo Hi, I am.... 0 08-18-2014 06:46 AM
Burro Vinyl Roof Seam Cover Fell Down Muriel Problem Solving | Owners Helping Owners 10 07-31-2013 10:11 PM
Burro center seam ThomasE Problem Solving | Owners Helping Owners 6 01-29-2010 11:08 AM
List 13 foot eggs with a vertical seam (Burro type) Matt, H General Chat 0 10-07-2009 10:06 AM
