Advice Needed - What Size Power Inverter To Have In Our Oliver ? - Fiberglass RV
Go Back   Fiberglass RV > Maintenance | Restoration | Modifications | Problem Solving > Electrical | Charging, Systems, Solar and Generators
Old 02-27-2015, 09:51 PM   #1
Trailer: 2015 Oliver Legacy Elite II 23' 6"
Hi .... We were just informed that the hull construction will begin on our Jan. placed order of our new Oliver Elite 23' 6 & I would like to add a power inverter to be used in conjunction with the four Trojan AGM battery's. I want to use the inverter mainly for the power usage while using the TV/DVD , satellite TV dome antenna & possibly the furnace for short periods. I have the option of a 600W(540) or the 2000W(1800) power inverters to be installed. I have read that if the inverter is too small working at near full capacity, the life span is shortened due to heat & if the converter is to large the xtra power draw on the battery bank is not good either. I hope this makes sense ... Thanks, John & Gwen Cole
John Cole is offline   Reply With Quote
Old 02-27-2015, 10:12 PM   #2
Trailer: 2015 Oliver Legacy Elite II - Hull #69
South Carolina
I got the 2000 watt on mine. It comes down to whether you want to run the microwave or not. The TV, stereo, lighting, furnace blower, water pump run natively on 12 volt. The king dome is 12v as well. You do not need an inverter for the furnace. The air conditioner will not run off the inverter - you need shore power for that. The refrigerator and the water heater run on gas, but need a wee bit of 12v as well. The 110v mode for the water heater will not run off the inverter either.
So what you need an inverter for is the microwave and any 110v appliances you are going to carry - like a hair dryer, a crockpot, coffee pot, toaster or satellite receiver.
Anything with a heating element will draw down your batteries quickly. A satellite reciever is probably only 50-60 watts, so that is not anything to worry about. You can probably run a microwave (1000 watts)for 15-20 minutes without worry. A coffee pot (1500 watts) may be good to brew and then shut off - you don't want it to keep heating beyond 15 minutes. There are tables online that give you sample appliances and their expected draw over time.
The power to run the inverter is around 20% of the wattage it's generating. So if you are generating a low amount - like 60 watts for a satellite reciever - it's going to use 12 watts for the inverter. The good news is that they only provide what you are currently needing.
I figured that my loads would be light most of the time, but with the bigger unit, I could run the microwave on occasion. Otherwise, besides the price, there is no downside to your batteries to select the bigger unit for light loads.
Make sense?
One last thing - if you get the bigger inverter, they will wire up the trailer so that every outlet will get inverter power. If you go with the small one, they wire in a couple inverter only outlets - one in the video cabinet so you can hook up a satellite decoder.
Follow my blog - https://www.wincrasher.blogspot.com
Ron Merritt is offline   Reply With Quote
Old 02-27-2015, 11:03 PM   #3
Thanks for the reply & all the info. ... John & Gwen Cole
oliver
Power Inverter - a Question Mac B Problem Solving | Owners Helping Owners 7 11-13-2009 02:46 AM
Vector® 750 - watt Portable Power Inverter Kevin K Classified Archives 0 04-25-2008 10:55 AM
Wiring Inverter, Converter, and Power Transfer Relays. GeorgeR Modifications, Alterations and Updates 3 01-31-2008 11:50 AM
Power Inverter for Charging Laptop in the car? V'sGlassSleeper General Chat 24 09-03-2007 10:28 AM
Generator vs Power Inverter Bob H Electrical | Charging, Systems, Solar and Generators 15 09-05-2006 10:32 AM
