5th wheel scamp to a bumper hitch - Fiberglass RV
Old 11-16-2014, 03:12 PM   #1
Trailer: Currently Shopping
I am considering buying a 1985 5th wheel scamp but it can't be towed using the gooseneck with my pick-up. Truck is too high. I am looking to convert to a bumper hitch but do not know anything about it. Any sugggestions? Can I buy a conversion kit? Or will it have to be custom built?
Jiggs is offline   Reply With Quote
Old 11-16-2014, 03:22 PM   #2
Hummm. Now. Just because you can, doesn't mean you should. No, there isn't a conversation kit available. You'd have to build it. There's a reason Scamp doesn't offer the 5th wheel as a "bumper" pull. If they did, they'd open up their customer base. But since they don't.. don't you suppose there's a very good reason?
You CAN raise the trailer however. How much more clearance do you need to pull the 5th wheel safely?
Old 11-16-2014, 03:35 PM   #3
Paul O.'s Avatar
Here is one way to do it, of course it is not sanctioned by anybody responsible:
Fiberglass RV - suzuki11's Album: Imported to south korea - Picture
There is another way, I cannot put my finger on it, but it is here on this forum. Even this way you lose the advantage of fifth wheel towing - stability.
But as Donna says, you should be able to raise it enough.
Old 11-16-2014, 03:46 PM   #4
Paul O.'s Avatar
here is a picture of it:
http://www.fiberglassrv.com/forums/f...tml#post313891
Old 11-16-2014, 03:50 PM   #5
Paul O.'s Avatar
This one is scary:
http://www.fiberglassrv.com/forums/f...tml#post169361
Old 11-16-2014, 04:01 PM   #6
Bob Miller's Avatar
Trailer: Class A Motorhome
If nothing else you will have huge tongue weight. And, as the well known wisdom of Donna D sez, Just because you can doesn't mean you should.
Before adventuring into this idea I would have a talk with my insurance agent about coverage with an experimental towing arrangement.
Old 11-16-2014, 04:03 PM   #7
Pam Garlow's Avatar
Trailer: U-Haul 1985
It seems that if it was safely possible to make an adapter, Scamp would have done it by now...... and be raking in the extra money.
Pam Garlow is offline   Reply With Quote
Old 11-17-2014, 05:28 AM   #8
How high can an 85 scamp be raised?
Old 11-17-2014, 10:31 AM   #9
Trailer: Shopping for new RV
I have two possible easy and safe solutions...1.) sell the 5th wheel and buy a conventional trailer. 2.) Buy a suitable pickup truck that is rated for the task at hand.
If you continue on your current quest I would expect to see your setup on the 6 o'clock news covering the accident you cause.
Uplander is offline   Reply With Quote
Old 11-17-2014, 10:34 AM   #10
You need to park your truck in front of the 5r to check the clearance. The 5r hitch is preaty high to begin with.
Look for a Putnman Firehawk II hitch as it has a ball connection that is heighth adjustable. They are not made anymore but you may B able to find a used one.
Old 11-17-2014, 12:16 PM   #11
Steve L.'s Avatar
My mind immediately went to "What kind of truck is too high for the Scamp 5th wheel?"
Do you have some sort of aftermarket tires on it? Do you compete in those car crushing events at the fair grounds?
I'd need one of those second story escape ladders to throw out the door to enter and exit.
Steve L. is offline   Reply With Quote
Old 11-17-2014, 12:55 PM   #12
Bob Miller's Avatar
Truck bed sides on a lot of newer trucks, like the Toyota Tundra, are to high for a standard SCAMP 5th wheel mount. I'm sure other have the same issues.....
Old 11-17-2014, 03:37 PM   #13
Ridgelines have high sides and Fords tend to somewhat high.
If he has one like Steve pictured above then why not Jack The 5R to match the truck. Honda
Old 11-17-2014, 04:06 PM   #14
There's always this solution
Joe
Old 11-17-2014, 05:56 PM   #15
Trailer: 2010 Scamp 16
From what I have heard it is not the truck is too high but the sides are, even if you lowered the truck the bed sides would be in the way. Pretty sure it can be made to work if you only travel in a straight or nearly straight line. You just strap that hitch down with some spacer blocks. Add some chains so it can't slide off the back and away she goes.
Old 11-18-2014, 07:57 AM   #16
Paul O.'s Avatar
The new style of Scamp 19 hitch is a Reese bracket and rails. It has several inches of height adjustment to accommodate the depth of different beds. It is at the lowest setting in my Tacoma. Its bed is only 15 inches deep.
Old 11-18-2014, 08:16 AM   #17
Bob Miller's Avatar
An additional thought: While there is a slight difference in hitches between the one you are looking at and current production, you might try asking SCAMP what solutions they have for connecting your make, year and model pick-up to a new SCAMP 19'er.
I have heard that they have a lift kit of some sort.
BTW: Post what your vehicle is, someone here may have already found a solution.
Old 11-24-2014, 07:13 AM   #18
Jared J's Avatar
Trailer: 1984 19' scamp
Kansas
Several things.
1. The current axle is likely shot.
2. It likely has 13" tires.
3. A lift is available from scamp, although it requires cutting and welding, that will be necessary anyway, if your axle needs to be replaced.
I towed mine home with an adapter the PO had built. It braced back to the bumper with chains. The titan had zero issues pulling it that way.
Name:	ImageUploadedByFiberglass RV1416834488.405949.jpg
Name:	ImageUploadedByFiberglass RV1416834532.315363.jpg
I couldn't bring myself to leave it that way. It was so low, it put a small dent in the tailgate when I turned sharp while pulling it home.
I put a new axle, 3" lift, 225/75/15 tires on it, and made it a real fifth wheel.
Name:	ImageUploadedByFiberglass RV1416834719.386615.jpg
Name:	ImageUploadedByFiberglass RV1416834777.993261.jpg
It was well worth the effort, IMHO.
Towing fifth wheel versus towing bumper hitch drstock Towing, Hitching, Axles and Running Gear 67 02-20-2014 02:04 AM
5th wheel hitch to hitch pull jackstrr Towing, Hitching, Axles and Running Gear 9 07-19-2011 04:19 PM
5th wheel to bumper hitch jackstrr Modifications, Alterations and Updates 7 06-11-2011 08:50 AM
Hitch Aid / Bumper Guard Behind Hitch Ball? Parker Buckley Problem Solving | Owners Helping Owners 12 01-27-2008 04:05 PM
5th wheel bumper pull jeff y Towing, Hitching, Axles and Running Gear 0 01-01-1970 12:00 AM
