New Scamp Rib Door Seal - Fiberglass RV
Old 12-20-2014, 09:03 AM   #1
TomK's Avatar
Trailer: Scamp 16
Scamp came up with a new door seal. I ordered one and it looks promising. It appears to collapse and form a seal easier than the "D" shaped seal they were supplying, and it's made of closed cell foam, so much better at keeping out rain than the open cell seals installed on recent trailers.
*New Rib Door Seal* : Rib Door Seal
Tom
TomK is offline   Reply With Quote
Old 12-20-2014, 10:52 AM   #2
floyd's Avatar
We started ten years ago with an "Omega" shaped seal which works fine, switched to the "D" shaped seal on subsequent installs, which was more attractive, even convinced Scamp to offer it aftermarket.
I see now Scamp has found what may be both an attractive and effective seal, worthy of original installation!!
A friend just bought a new Scamp with this new seal factory installed.
I think I will order one to replace the "Omega" seal on my trailer, and test it out!
Old 01-14-2015, 06:19 AM   #3
Trailer: In the market
I installed one on my Scamp 19, 1986 model. It fits much better but my door is bowed at the bottom so I added some severe weather stripping on top. The cabin is more sealed than before. I have to push on the door slightly when closing..a good thing.
Billy32303 is offline   Reply With Quote
Old 01-14-2015, 08:43 AM   #4
TomK's Avatar
Trailer: Scamp 16
That's good to hear Bill. A couple of us are bringing the new seal to Scamp Camp in Sebring for an unscheduled "Seal-a-Thon" event. Hoping for some nice warm weather.
Tom
Old 01-15-2015, 09:39 AM   #5
floyd's Avatar
I installed the new flanged seal on EggySue yesterday. it looks great and appears to be the most effective seal yet. I still would not use it for the threshold though, the square solid closed cell foam is still best for that.
Old 01-15-2015, 10:06 AM   #6
Carol H's Avatar
Thanks Floyd! for sharing that info as I was just going to ask about how the new stuff worked out on the threshold.
I have the D seal around the door and very happy with it but kept using the foam at the threshold but my pup decided to chew it up on last camping trip, wondered if I should switch it to the new stuff or stick to foam for the threshold.
Old 01-15-2015, 10:21 AM   #7
Trailer: Escape 21
Georgia
To those who have installed the new seal, which way did you orient the flap/flange? Facing inside or outside? An inquiring mind wants to know.😜
Sent from my LG-V410 using Fiberglass RV mobile app
lijMichael is offline   Reply With Quote
Old 01-15-2015, 11:56 AM   #8
I too have the D-seal with the closed-cell foam at the bottom. It rests against my alum. "kick plate" and I have had no issues with water with this setup. I havent ever really considered what I would replace the closed cell foam with when I do have to make a change.
Floyd....pics of the installation of the new seal??????
Old 01-15-2015, 12:01 PM   #9
TomK's Avatar
Trailer: Scamp 16
The lip or rib should face away from the door opening. It appears the lip would actually seal tighter with air pressure at speed.
Floyd, what square foam seal are you referring to? The one that came with the trailer is open cell foam, and the bottom (threshold) is what failed in the first place. It didn't even make it home from Backus.
Tom
Old 01-16-2015, 11:20 AM   #10
floyd's Avatar
Tom
The gasket change at Scamp was long overdue.
I changed mine immediately after purchase almost eleven years ago.
The threshold gasket, like the omega gasket, was procured from local sources. (JCWhitney I think)
The threshold gasket I used is closed cell, dense and strong.
I don't have a part # but I will look for a source.
Old 01-16-2015, 11:54 AM   #11
Pictures???
Old 01-16-2015, 08:23 PM   #12
floyd's Avatar
Originally Posted by Darral T. View Post
Pictures???
I just went out and took a few pics of the new gasket.
That board for a background was a mistake, maybe I'll get better pics tomorrow.
Pardon the interior, we are in the process of several more mods... piezo stove lighters, HD TV, LED DOT lights, plus getting ready for Sebring.
Click on the pics to get a better view maybe?
Old 01-17-2015, 05:05 AM   #13
TomK's Avatar
Trailer: Scamp 16
Good Job Floyd. I don't have access to our trailer until we pull it out of storage for the trip to Sebring, so I'll wait and change the seal then. It looks good. Without being able to see the threshold now, I'm not sure what I'll need until I do. It looks like the "Rib" lays flat and should work well. Scamp's R&D with the seal mfr. should help a lot of folks with seal problems.
Tom
Old 01-17-2015, 06:50 AM   #14
Ian G.'s Avatar
I installed an almost identical seal on my Boler and it is working great. I installed mine around the door lip (on the door) rather than around the door opening, the lip facing out. After the initial install the door needed a LOT of force to close, but by leaving the door closed for a few days after install it now opens and closes easily (sounds like a quality car door closing) and it seals perfectly.
I bought it through Vintage Trailer supply
Airstream Door Gasket
Old 01-19-2015, 09:45 AM   #15
Thanks Floyd! Looks good. I'd like to see it with the door closed. Does the lip protrude much past the door when it's closed? Just curious.
It looks like this seal "fans" out with that extra lip. I can see it would have GREATLY eliminated a problem I ran into with the stock D seal when there was a gap at the top!
Good stuff! Thanks for the installation pics. Also IAN, thanks for the link on yours as well. Scamp is charging $25 for theirs but it looks to be a bit larger and possibly longer since they say it will go around the entire door perimeter including the bottom!
This has been a MUCH-needed item on the Scamp.... better late than never.
Old 01-19-2015, 05:33 PM   #16
floyd's Avatar
It doesn't show at all with the door closed. Scamp was very generous with the gasket I had plenty left over.
Old 01-19-2015, 05:52 PM   #17
TomK's Avatar
Trailer: Scamp 16
Sounds good Floyd. Stop by site 026 at Scamp Camp and give me some moral support when I put our seal on.
Tom
Old 01-20-2015, 09:29 AM   #18
That will help keep the seal from "aging" if it's not over-exposed to the elements. I know mine is concealed for the most part behind the door.
Sounds like Scamp DEFINITELY has a winner with this seal. Now I'd like to see a NEW Scamp with it installed. I take it the "lip" is very flexible which is most likely the reason they will now install it at the factory on new trailers. Before, they were concerned (as per Kent Eveland) that the more stiff D-shaped seal could push out on a new door a bit causing problems after it fully cured. That's why they requested a few months of curing before installing the seal.
Old 01-20-2015, 10:56 AM   #19
TomK's Avatar
Trailer: Scamp 16
If I have any left over after installing mine, I'll send you a piece and let you know how it worked out Darral. It sounds encouraging so far.
Tom
Old 01-20-2015, 11:07 AM   #20
Thanks buddy! Looking forward to Piney to see the installation and how well it works. I agree, I think you will like the seal! I'm not sure I wouldnt attempt it on the bottom as well and be done with it since they sent enough to do it. I will take the sample piece you send and just look it over to see if it would be a viable option to replace the bottom sponge seal. With my kickplate, there hasnt been an issue with the one that's installed though. (so maybe if it aint broke? )
I know you and your work and you wont have any problem with it Tom... Thanks for offering the sample.
Tom
New door seal source? msinger919 Problem Solving | Owners Helping Owners 5 08-03-2013 08:03 AM
Exterior Outer Rib Seal elilley Problem Solving | Owners Helping Owners 2 07-01-2013 10:00 AM
Prime Rib/ Porter house sherry loving o Camp Cooking, Food & Recipes 1 03-29-2009 08:12 PM
