1978 Boler 1700 water lukewarm - Fiberglass RV
Old 01-14-2014, 02:51 PM   #1
Trailer: Bigfoot 2500 truck camper
Haven't been around these parts for a while. I am itching to snowbird out of the north in February and remembered that we were having problems with water temperature in September before winter hit. Both in the shower and at the kitchen sink after the water heater pilot was lit and the thermostat set to high. The heater appeared to be operating correctly as it had before but after and hour or two of heating the water was only somewhat warm. Managed to take a shower in it but it was not the experience it was before and at the sink the water was not hot enough to shave.
There are no leaks in the heater, the pilot seems to operate properly. We could hear the burner cutting in and out. Has me puzzled where to start or what to look for. Help?
Rene is offline   Reply With Quote
Old 01-14-2014, 03:01 PM   #2
Bob Miller's Avatar
Trailer: Class A Motorhome
With normal moderate temps you should have hot enough water for a shower in less than 15 minutes.
Did you check the volume of hot water flow alone, you may have a kinked or pinched hot water line somethere and there isn't enought hot water to overcome the cold.
And, by chance, is there a bypass on the water heater, if this is open the water won't be flowing through the water heater.
Good Luck
Old 01-14-2014, 04:57 PM   #3
Hi Bob, there is a bypass and I would think that if it was not closed, the water heater would not fill up. The lines themselves I will have to check out thoroughly by tracing them I guess.
Old 01-14-2014, 05:04 PM   #4
Bob Miller's Avatar
Depending on how your bypass is plumbed, if the valve(s) were partially open it could let cold water flow into the tank as well as bypass it and add cold water to the output side.
Just a thought.
boler
1978 Boler 1700 Before and After Rene Modifications, Alterations and Updates 36 09-27-2012 01:48 PM
SOLD: 1978 Boler 1700 17' Derek Classified Archives 4 09-07-2010 08:35 AM
1978 Boler 1700 (17ft) For Sale Derek Classified Archives 5 05-26-2010 11:02 AM
1978 Boler 1700 for sale Rick kl Classified Archives 3 04-22-2010 12:52 PM
