Trillium Table Leaf Mod - Fiberglass RV
Old 06-24-2019, 11:58 PM   #1
Trailer: Trillium
CA
Hi all!
So I used some ideas here (including the leaf concept for a shorty table) and did a lot of head scratching in the aisles at Joes Hardware. Ended up with something I quite like that also works well!
A-1 grade 3/4” birch ply ($83/4x8 sheet) clear lacquered. 22” 100lb load drawer slides (but used horizontally, load dramatically decreases; not important to me for light table usage). Copper hanger tape. Buncha Little screws. Latches, model 4001 220lb load. Rubber foot .
Bed strength is solid. Latches firm it all up but might add another pair to stabilize end piece to leaf. Shorty table is rock solid, as it locks into latches when leaf is out.
6B0FC6A3-799B-4880-B69B-F197C6EB59CF.jpg   E17B253F-CE71-4D94-8443-BE7771B5C469.jpg
2895D066-D880-4594-9276-2EF5F64511FB.jpg   BC3AF16E-8D1C-427F-B261-7A3BBEDECEE0.jpg
emeraldzippy is offline   Reply With Quote
Old 06-25-2019, 10:12 AM   #2
Trailer: Trillium
CA
More pics.
And Scott H was the member whose post in 2009 gave me the leaf idea, although I wanted to keep the swing bar function so I cut the middle segment out, leafing (pun!) the small base piece that's against the wall.
CBBAB8BE-92A4-414E-8CC9-FD28DAC088C8.jpg   132FB653-152C-4063-BE06-1E8CBB060EE0.jpg
ED61F9BC-7D3B-419D-90CF-E428D70382C0.jpg   6C5B2470-4031-4A63-A24E-0E2FCEE04719.jpg
Old 07-11-2019, 05:00 AM   #3
Trailer: 1976 Trillium 1300
New Brunswick
Hi Nice work ! Is the center leaf narrow enough to store it under one of the cushions at either bench when not in use ? I'm curious about the "bar" on the back wall above the short leaf . Is it a factory piece ? I've been thinking about doing something to gain more floor space in my Trillium too. Duane
p.s. I'm tired of retrieving items that slide way under the table on the floor.
getaway1 is offline   Reply With Quote
Old 07-11-2019, 04:11 PM   #4
Trailer: Trillium
CA
The leaf is smaller than the width of the seat cushions, so you can either store under, or behind the backrest pads; width comes right of to bottom edge of window. Future plan is to make an attachment on the outside. The leg has a square cut dowell goin all the way up the pipe, so length can be adjusted on the fly.
The bar is factory, it’s the swing point for table to bed conversion. I’ve seen the hardware kit sold via trillium still! That bottom bracket is half open, so the bar pops out and stays with the table.
I almost put in a post style, but wanted to preserve the floor space too!
Old 07-15-2020, 03:35 PM   #5
Trailer: Trillium
Hi! I have just purchased a trillium 78 trailer. There is no table ��. Your table is such a great idea! I would be gretful for a detailed plan so that I could build one.
Ryannichols78 is offline   Reply With Quote
Old 07-15-2020, 03:43 PM   #6
It depends on which MODEL Trillium you have. The 4500 table is much different than the Trillium 1300. The one pictured above appears to be the 1300 model. Trillium made many models, with lots of differences.
I do like the shorty table. Nice!
The "bar" on the back wall is a Trillium 1300 feature.
Old 07-15-2020, 03:48 PM   #7
Trailer: Trillium
Bill, thank you for your reply. Where do I find my trailer's model number?
Old 07-15-2020, 04:10 PM   #8
1. Measure overall length from hitch to rear bumper. 1300 is the smallest, 13 feet overall. 4500 is approximately 15 feet overall. From what I have read, the 4500 is 4500mm long, which is slightly less than 15 feet. Overall length, not the length of the tub!
2. Look at the data sheet posted inside the closet door.
3. The title for your trailer.
4. Bed size/rear dinette size.
5. Look at pictures, lower kitchen cabinet is noticeably different between the 1300 and 4500.
6. 1300 and 4500 have fiberglass interiors (cabinets, closet and benches). Wood "like" doors and drawer fronts.
7. Models with wood interior are bigger and are not a 1300 or 4500.
Google Trillium images. To the untrained eye, a 1300 looks just like a 4500. But one is two feet longer.
Check my Trillium Project Page: https://www.facebook.com/Bills-1977-...dmin_todo_tour
trillium
Trillium 1300 dinette leaf storage JBjunior Problem Solving | Owners Helping Owners 10 06-14-2014 03:54 AM
big MOD's of our 1981 Scamp "Mod Pod" CAROLPHAYES Modifications, Alterations and Updates 26 06-11-2014 09:38 AM
ideas for hinged table leaf theresa p Problem Solving | Owners Helping Owners 0 02-10-2009 02:21 PM
Small Table Mod Legacy Posts Modifications, Alterations and Updates 2 08-18-2003 08:16 PM
