1975 trillium bargeman l-300 lock replacement - Fiberglass RV
Old 08-10-2019, 10:36 AM   #1
Trailer: trillium4500
I have a 1975 trillium need a lock replacement any help
lables is offline   Reply With Quote
Old 08-10-2019, 11:47 AM   #2
John in Michigan's Avatar
Trailer: 1979 Boler 1700
The L300 and L400 have been out of production for quite a while. Checking the Vintage Trailer Supply website, they sometimes have reconditioned L300s in stock for $200. Are you positive that its an L300? My Trillium 4500 and others that I've seen have an L400 installed. Just checking. In any case, you can also monitor ebay and kijiji for a replacement.
Old 08-10-2019, 11:53 AM   #3
+10 They show up on eBay all the time. Value is pretty well established. Sadly, my 1977 uses the L400 which tends to go for the most $$$. If you plan to keep the trailer a long time, a few backups can be prudent. I have two backups right now and a NOS repair kit.
The rebuilt L300 mentioned above for $200 is a good deal if that is what you need. Keep your old broken one as a donor.
Bargman locks were used on many trailers back in the day, so the supply is low and the demand is high. Be sure to spell the name correctly when searching on eBay (no e).
Old 08-10-2019, 12:03 PM   #4
Alex Adams's Avatar
Trailer: 1979 Boler B1300
New Hampshire
If you have an old-fashioned locksmith shop that has been around for a number of years, they may be able to fix your lock depending upon what is broken. I have one I go to that has been around since the 50's and they have all kinds of old stock and parts.
Old 09-09-2019, 11:49 AM   #5
Trailer: Burro
Bargman Travel Trail Locks
My Burro has a Bargman door lockset and the actual locking lever broke loose. It seems like the weak point in these locks. I ended up using a center punch, drill, self taping screw and washer. The lock now works better than ever. I've attached images of the issue and repair.
1) Open the exterior latch and under it you'll find a retaining washer that secures the inside handle. Remove it'
2) Remove the two bolts on the inside of the lockset and remove the two halves.
3) In the first picture you'll see an area where there was a washer that had been held by the mushroomed end of the post.
4) As in picture #2 use a very small center punch to put a starter spot in the center of what is left of the post.
5) Picture #3 shows a small self tap screw and washer. ( Be careful to chose a drill and screw no more than 1/2 the diameter of the post diameter.
6) Picture #4 shows the self tap screw and washer installed.
Jolly Roger is offline   Reply With Quote
Old 09-09-2019, 01:57 PM   #6
Trailer: 13 ft Scamp
Since I’m his seems like a very common problem
I think many others would appreciate your fix /step by step
Old 09-09-2019, 03:25 PM   #7
Meant to say this is a common problem
Maybe you could post your fix
Old 09-09-2019, 05:54 PM   #8
Trailer: Burro
I updated the post to include the steps I took to repair my lockset.
trillium
Replacing Bargman L-300 with new Trimark lock on a Trillium Tugger Modifications, Alterations and Updates 17 10-06-2015 06:17 AM
CA | SOLD ~1975 trillium $4,300 piersons Classified Archives 4 04-15-2014 12:35 PM
