Boler 1300 Weight Distribution Question - Fiberglass RV
Old 11-22-2017, 03:33 PM   #1
Alex Adams's Avatar
Trailer: 1979 Boler B1300
New Hampshire
I am looking at adding the following to my Boler 1300:
45 pound fridge on driver's side of trailer
25 pounds of stabilization jacks on driver's side
126 pounds of battery to the curb side of trailer
I have read threads concerning side to side stability. My question is have any owners put more weight about 56 more pounds on the curb side of their 13 footer without any side to side stability issues?
I was think of testing with the 25 pounds of jacks on the driver's side and one 63 pound battery on the curb side to see if I have any problems. I would rather hear from someone who has done something similar with the weight distribution.
Old 11-23-2017, 07:24 AM   #2
Jon in AZ's Avatar
There was a thread a while back that explored how much left-right imbalance is acceptable. There were no clear answers, but differences of up to 10% of GAW seemed pretty common and no cause for concern. In your case 60 pounds is only 5% or less of the axle weight.
Make sure the heavy side doesn't exceed the tire rating (unlikely!) or half the axle rating (original Boler axles were only rated for 1200 pounds, I believe, but replacements usually up the rating).
Old 11-23-2017, 03:24 PM   #3
If you can, measure the real weight on each wheel, then adjust tire pressures accordingly. If, as Jon says, you have a difference less than 10% it would not be enough to bother. A larger spread might result in faster tread wear on one side.
boler, weight
is my weight distribution hitch worth the tongue weight and effort. beachcamper54 Towing, Hitching, Axles and Running Gear 24 01-25-2014 12:41 PM
weight distribution hitches Ian-Vicki Towing, Hitching, Axles and Running Gear 16 07-09-2007 02:47 PM
Single Bar Weight Distribution Hitch Gina D. Towing, Hitching, Axles and Running Gear 33 03-19-2007 12:11 PM
Weight Distribution Trailer Hitch Systems John D. Problem Solving | Owners Helping Owners 1 01-10-2006 04:53 PM
The importance of proper weight distribution Legacy Posts Jokes, Stories & Tall Tales 6 03-21-2003 07:48 AM
