Leaf spring vs torsion axle: 1998 Scamp 13' - Fiberglass RV
Old 06-27-2014, 03:23 AM   #1
Idaho
I'm just starting to update my 1998 Scamp and was curious about the differences between the two axle choices. The leaf spring is much cheaper and will be easier to fix, so I guess the real question is whether a torsion axle is worth it and if there are clear advantages over the leaf spring? I'm hoping to increase the clearance by adding 15" tires, but am uncertain about the logistics of this as far as the type of axle, etc. Any information you could provide would be really helpful!! Thanks!
katidesc13 is offline   Reply With Quote
Old 06-27-2014, 04:21 AM   #2
Lyndon Laney's Avatar
Trailer: 1996 19 ft Scamp 19 ft 5th Wheel ('TOGETHERNEST' SLEEPS 8
Leaf springs on these lite trailers tend to break quite easily if for some reason your brakes are set too high and you stop quick as the lite spring will tend to snap off due to the quick twist
Lyndon Laney is offline   Reply With Quote
Old 06-27-2014, 04:27 AM   #3
Idaho
Are you referring to trailer brakes? I'm pretty certain the 13' Scamp doesn't have trailer brakes.
Old 06-27-2014, 04:36 AM   #4
Yes If applied too hard and quick light spring tends to snap
Old 06-27-2014, 01:28 PM   #5
Tom Trostel's Avatar
Send a message via AIM to Tom Trostel Send a message via MSN to Tom Trostel
I own a 41 year old Compact Jr and a 34 year old Bigfoot. Both have their original leaf springs and both have been stopped with max braking repeatedly. I've read this forum for 10 years and have read very little about broken leaf springs. This is not the case for worn out rubber torsion axles, which is very frequently discussed.
Tom Trostel is offline   Reply With Quote
Old 06-27-2014, 03:12 PM   #6
Idaho
The 13' Scamp originally has a torsion axle. I've read in these forums about some kind of "bounce test" to verify the quality of the current axle but am not quite understanding what this is. As it sits, I may just put the new tires on it for now and save money to invest in another torsion axle to help increase clearance. Another member stated she used the dexter axle with a 45 degree and added 15" tires to get 6-8" on clearance. I definitely need to do more research!! Thanks!!
Old 06-27-2014, 03:36 PM   #7
Roy in TO's Avatar
The bounce test is simple. Get someone to stand on the rear bumper and bounce the trailer up and down. At the same time watch your torsion arms. If the arms are moving (i.e. rotating) your axle is doing what it should. If the arms don't move and the only bounce you get is from the tires, you axle is shot.
Alternatively, jack up your trailer, remove the tire and see if you can get the torsion arm to move up and down at the spindle end using a pry bar.
You should get about 3" total movement.
Think of a torsion axle like a MacPherson strut. It is your spring and shock combined.
axle, scamp
Torsion Axle vs. Leaf Spring axle camper1887 Towing, Hitching, Axles and Running Gear 9 10-01-2012 05:32 AM
torsion springs or leaf springs Cat futrell Problem Solving | Owners Helping Owners 18 08-26-2012 08:12 AM
1975 Scamp 13 leaf spring conversion? pudgepuss Towing, Hitching, Axles and Running Gear 10 07-23-2011 09:39 PM
Leaf Spring/Axle replacement for a Scamp 13 DanMurphy Towing, Hitching, Axles and Running Gear 8 02-16-2008 02:56 PM
Broken leaf spring 1965 hunter compact II mikecontos Problem Solving | Owners Helping Owners 3 08-07-2007 01:07 PM
