01-21-2018, 05:23 PM
Trailer: Trillium
Door hinges \ lock for Trillium
A newbie to this site but a proud owner of a 1977 Trillium 4500. We want to change the outside door hinges and get a new door handle\lock. Can anyone offer any suggestions to help?
Thanks.
Michael D.
01-22-2018, 10:43 PM
Trailer: Trillium
David..
Thanks for the info.. But if it's a L300 on a 1975 Trillium, will the same Trimark work as a replacement??
Chris from Comox..
01-22-2018, 10:46 PM
Originally Posted by Chris from Comox
David..
No.
01-23-2018, 06:05 AM
Trailer: Boler Voyageur 1977
Quebec
Originally Posted by David Tilston
No.
These are hand made. I'm pretty sure the aluminum cover plate could be made to any size at minimum added cost. I just won't be as plug and play as the standard one, some fitting will be required on your side.
01-23-2018, 03:05 PM
Trailer: Trillium
David..
Is there any sort of replacement for the L300 on a 1975 Trillium and if so have you any info that you can share on this topic??
Chris from Comox..
01-23-2018, 03:44 PM
David..
Chris, I am sorry to say that there is no compatible replacement. Phillip is correct in that the procedure to install a Trimark latch in the hole of an L300 should be similar to the L400 procedure. Basically cover the larger hole with a plate that has a cut out for the new latch.
This company claims to have a replacement for an L300:
https://www.rvautoparts.com/AP-Produ...SABEgLGb_D_BwE
Maybe also look at these threads:
http://www.fiberglassrv.com/forums/f...ent-58136.html
http://www.fiberglassrv.com/forums/f...ium-50835.html
I hope that helps.
01-24-2018, 01:25 AM
Trailer: Trillium
David.. Thanks for clearing this up for me.. While my forte is wood, I do have some experience shaping aluminum and will give it a try when needed ;-)
Chris from Comox..
