Nissan Frontier/Escape 5.0TA Hitch? - Fiberglass RV
Old 02-17-2015, 03:18 PM   #1
Trailer: Escape Trailers
Massachusetts
We are in the process of buying a 2014 Escape 5.0TA. What make and model hitch do you recommend for a Nissan Frontier?
Stretcher is offline   Reply With Quote
Old 02-17-2015, 06:23 PM   #2
Just go here and order the hitch that bolts directly to your truck.
2014 Nissan Frontier Trailer Hitch | etrailer.com
When I installed the hitch on our 2012 Frontier Crew Cab, it took less than an hour and I did it alone. The hitch is custom made for the vehicle and even comes with the bolts to bolt it to your frame that has the nuts already welded on.
I did have to order a wiring system that i stalled multiple relays behind the front passenger right kick pannel to already installed wiring. It also came with a wiring harnis to plug into existing wiring back at the hitch location.
Ask E Trailer what you will need.
I i stalled a 2 inch receiver.
Old 02-18-2015, 01:20 AM   #3
LeonardS's Avatar
Trailer: not yet
I think stretcher was inquiring about a fifth wheel type hitch as the trailer he's getting is such.
LeonardS is offline   Reply With Quote
Old 02-18-2015, 06:38 AM   #4
C&G in FL's Avatar
Trailer: 2015 Escape 5.0TA
David-
I would check with eTrailer or look at their website. If you already have rails in the bed of your truck for the Scamp 19 hitch (made by Reese), and 5th wheel hitch from any manufacturer should fit as the rails are made to industry standards. Reese does make a conventional 5th wheel "head" that will fit the basic framework of the Scamp hitch, but it holds the king pin with a sliding bar, rather than jaws which surround the king pin. I am replacing my Scamp 19 with an Escape 5.0TA and opted for a Curt 16K hitch. If I recall, it was $429 w/free shipping from eTrailer and as stated above, it fits perfectly in the existing truck bed rails.
Old 02-18-2015, 09:27 AM   #5
eagle of flight's Avatar
Trailer: burro 1982
Hi Strecher. What size engine do you have in your frontier? I have a 2014 frontier king cab with a 2.5 4 cy. I plan to pull a 13 ft 1982 burro. I hope that I have enough power.
Chiefonelung
eagle of flight is offline   Reply With Quote
Old 02-18-2015, 10:02 AM   #6
My bad on not realizing it is for a 5-R. You will still need the wiring accessories and so look around on the internet for the package. I bought mine off the internet, not from Nissan.
Old 02-18-2015, 01:26 PM   #7
Trailer: Escape 5.0 TA
W. Mass
If you need to add a 7 pin, you might consider an in the bed connection, easier to get to. I have both and use the in bed one. It's a 90 degree in the side wall.
Bob & Deb
padlin00 is offline   Reply With Quote
Old 02-18-2015, 05:12 PM   #8
C&G in FL's Avatar
I would think that the OP already is wired. If you read his profile, he currently has a Scamp 19.
Old 02-19-2015, 12:24 AM   #9
Trailer: Escape
What model Fronty are you considering or do you already have one. I tow my 5.0 with a crewcab model the reason being I need passenger capability, but I never carry passengers other than my wife if I'm towing the trailer. As far as I can figure I am within 100 lbs of the max weight the truck can carry. I know someone who has has put 50,000 plus miles on his rig with this combination, he has the 5.0ta now and is still putting on the miles. Personally I would get the King Cab model and get an extra 200 lbs. to play with. You don't need a real heavy duty hitch because the trailer is so light, the smallest and lightest we could find was the reese 15k. I would consider a slider though it could help you out in tight parking situations. Good luck in what ever you choose to do.
Not so Big Al is offline   Reply With Quote
Old 02-19-2015, 09:53 AM   #10
1ATony's Avatar
Trailer: Dutchman
Massachusetts
What year is your Nissan Frontier, we're a dealer for Curt. I could get a price for you, if we have a trailer hitch available for your truck.
Tony @ 1aauto.com
Tony
1aauto.com
Tow Mirrors - Trailer Hitch
1ATony is offline   Reply With Quote
escape
Escape 5.0TA storage question Bob and Julie General Chat 26 10-31-2014 01:56 PM
Nissan Frontier Wired and Hitched Raz Towing, Hitching, Axles and Running Gear 19 05-09-2013 04:05 AM
Anyone towing a 16' with Nissan Frontier? Michael D Towing, Hitching, Axles and Running Gear 5 11-16-2009 11:20 AM
Nissan Frontier 4Cyl - Camper Options Darral T. Towing, Hitching, Axles and Running Gear 30 09-15-2009 08:20 PM
Will Nissan Frontier Short Bed tow 5th wheel Scamp?? Betty L. Towing, Hitching, Axles and Running Gear 6 02-03-2007 05:22 PM
