1984 Bigfoot 17" furnace problem - replacement? - Fiberglass RV
Old 11-01-2016, 11:21 AM   #1
Hi,
I have been unsuccessfully trying to find a replacement gas control valve for the Hydro-Flame FA79(?) furnace in my '84 Bigfoot. The problem with the controller is that it opens the main burner valve in pilot lighting mode which is not good.
My next consideration is to replace the furnace and I'm wondering how easy that is. Has anyone replaced an old piezo furnace with a newer Atwood 7912 model that has direct spark? That would be a nice upgrade from having to light the pilot. Any suggestions on where to buy a replacement furnace in Canada?
threepine is offline   Reply With Quote
Old 11-05-2016, 12:31 AM   #2
Tim D.'s Avatar
Trailer: 1986 17 ft Bigfoot
In our 1991 Bigfoot we had the pilot model furnace replaced with an electronic ignition model when the blower bearing went bad. We paid an experienced mobile RV tech to do it. The install was easy. He struggled mightily removing the old one, which was stuck. Better him than me.
Tim D. is offline   Reply With Quote
Old 11-05-2016, 08:59 AM   #3
That is great to hear. Thanks for letting me know it is possible and relatively easy.
Old 11-06-2016, 09:00 PM   #4
Trailer: bigfoot
I replaced my furnace in a 86 17ft a few years back and it was a fairly easy task. As the other poster said mine was also stuck but other than that it was easy.
krusty is offline   Reply With Quote
Old 11-07-2016, 12:28 AM   #5
40bpm's Avatar
Trailer: '02 Bigfoot 17'
If the day comes when I need to replace the furnace in my '02 Bigfoot, how did you get it unstuck? Brute force? Intelligent influence? Persuasive hammer?
40bpm is offline   Reply With Quote
Old 11-07-2016, 06:51 AM   #6
Trailer: bigfoot
If I remember right, it was stuck where the furnace connects to the exhaust vent. I just kept pulling the furnace and kind of working it side to side. Again as I said it was a fairly simple job.
Old 11-07-2016, 07:03 AM   #7
Trailer: Boler 13 ft
In my 79 Boler I Replaced my DuoTherm standing Pilot with an electric spark unit I baught second hand from a dealer. It had come out of a pop-up and fit right in and the face plate fit right in the mounting tabs from one to the other.
I installed it and it came out with just a wriggle this way then that to get the exhaust pipes to slide. I did take all the screws out of the exerior flange just in case they would catch on the inside somewhere.
Been working fine now for the 4th season.
Old 05-04-2017, 11:29 AM   #8
Still without a furnace. Twice now I've ordered a new furnace and after waiting a month was told they are unavailable. I contacted Atwood this morning and found the 7900 series has been discontinued and that I might have problems finding a replacement.
They told me their new similar line are the AFSD series. Just wondering if anyone has managed to replace their furnace with this new model.
Old 05-12-2017, 08:32 PM   #9
Trailer: BigFoot
We replaced our with a vent free Olympic Wave. It keeps us nice and warm
We made a panel to fit where the old furnace was and cut the hole for the new unit. It has zero clearance behind it
Amy
1981 Bigfoot B17 Standard
4x4 Toyota FJ Standard 6sp
www.directuganda.com
Mountain Moma is offline   Reply With Quote
Old 05-12-2017, 10:11 PM   #10
Gilles's Avatar
Quebec
You look with Propex?
https://www.propexheatsource.co.uk/country/canada
Gilles
Bigfoot 25B21RB.
Gilles is offline   Reply With Quote
Old 05-12-2017, 10:20 PM   #11
Attachment 105959Attachment 105960
Wow, thank you very much! That might be a great solution for us. I love the idea of not having a fan come on during the night. Do you happen to know which model you put in?
Old 05-12-2017, 10:21 PM   #12
Originally Posted by Gilles View Post
Thanks, I'll check that out too!
Old 05-13-2017, 12:24 AM   #13
Trailer: BigFoot
We put in the 6000. We have a 17b and it can keep it very warm. I would start it in the morning when I was working on the trailer and had a small electric heater with a fan I would start at the same time in less than an hour it would be over 80 in there.
I never let it run over night as it was a bit of a construction zone but on low it would keep it between 50 and 60 even if it was way below freezing outside by itself
We got the mounting ring because of where it was located instead of just doing the wall mount and you do have to order the elbo fitting if you do the mounted one.
We ordered ours online and it goes on sale if you watch
Amy
Old 05-13-2017, 08:51 AM   #14
Thanks Amy, that is great to know. I am in Alberta too and the only place I can find one in Canada is Amazon but surprisingly the Wave-8 is a lot cheaper than the 6. I guess I'll go measure the space to see if a Wave-8 will fit.
Old 05-13-2017, 09:00 AM   #15
Trailer: BigFoot
We ordered from amazon.com
It was cheaper even with the exchange
With the free shipping we added in a few other things like the elbo fitting and it all shipped free.
Amy
Old 05-13-2017, 09:27 AM   #16
Thanks again. I see shipping as $100 and that turned me off a bit but I do have a Canadian Prime membership so I will see if that works or else try a temporary US one.
I really appreciate this as I think it will be a great solution and battery saver. We don't camp in the winter but do in the off season so it should do the trick.
bigfoot, furnace
"Camping" vs. "Traveling" Timber Wolf General Chat 54 08-07-2016 12:32 PM
1984 Burro "Bunk House" Sleeps 5! Jon Munn Modifications, Alterations and Updates 6 07-18-2012 11:16 PM
Some "before" and "after" shots..... Don & Viv Modifications, Alterations and Updates 13 07-29-2010 04:52 PM
Weights:"older model","later model" 17 ' Bigfo Joseph Olajos Towing, Hitching, Axles and Running Gear 8 04-05-2010 05:56 PM
For Sale: Furnace"Suburban" 1976 Boler petramarc Classified Archives 0 04-22-2006 10:52 AM
