Bigfoot "Bunks" - Fiberglass RV
Old 10-02-2017, 03:39 PM   #1
Trailer: Bigfoot and Casita Spirit Deluxe
New Mexico
Bigfoot "Bunks"
As I understand it, the 17 foot Gaucho model has a cabinet above that can be turned into, with the help of a foam mattress, a bunk for a wee person. In a conversation today I found out(was told) that in the center bath model the bainet over the convertible dining booth, can pull out as a bunk.
With this post, I was hoping for two things.
I would like to confirm that the "cabinet Bunk" did exist in the Gaucho model and the CB, center bath model.
Also would these work for a child up to 70 or 80 lbs(or how many pounds would be safe)....wouldn't be fun to have them land on top of you midway through the night!
Apltrez is offline   Reply With Quote
Old 10-02-2017, 03:55 PM   #2
Kenny Strong's Avatar
Utah
bunk
I have a 13' Bigfoot. There is a bunk under the front seat by lifting up the seat and pulling out the back to become the bed. supports on front left and right corners on an angle to the seat corner bottom. Do you have a toe trailer, with a front seat. Maybe you have a bunk up front. Not with a truck trailer ? I Don't know a 17' layout.
Kenny Strong is offline   Reply With Quote
Old 10-02-2017, 03:58 PM   #3
New Mexico
Nope, this is quite different in the 17....it comes out of the cabinet above the front eating area.
Old 10-02-2017, 07:20 PM   #4
Tom Trostel's Avatar
Send a message via AIM to Tom Trostel Send a message via MSN to Tom Trostel
The gaucho model bunk will support 70 lbs. The challenge is the close distance between pad and the ceiling. None of our 6 grand kids would sleep in ours.
Tom Trostel is offline   Reply With Quote
Old 10-02-2017, 07:32 PM   #5
The CB has the same height situation. The bunk surface to the ceiling is 14 1/2 inches in the center, and 13 inches at the ends without a mattress or pad. It is ridiculous to think that Bigfoot would even call this a bunk.
Old 10-02-2017, 07:36 PM   #6
New Mexico
Thanks Tom and Jack for reading between the lines...thought I could convince a 5 yr old grandson that the bunk would be the next "excelleny" adventure...maybe no
But at least glad I asked.
Greg
Old 10-02-2017, 11:18 PM   #7
40bpm's Avatar
Trailer: '02 Bigfoot 17'
I can't imagine anyone sleeping in the "bunk". Low ceiling with difficult access and egress. A cat would probably love it though.
40bpm is offline   Reply With Quote
Old 10-10-2017, 12:59 PM   #8
Trailer: Bigfoot 17
Quebec
photos of bunk setup?
We recently purchased an '84 B17 trailer and our 4 year-old is thrilled to be sleeping in the bunk area above the gaucho. However, we are perhaps overly cautious that she may fall through the folded-down cupboards! Were thinking of using a sheet of 1/4" ply underneath a 2" foam mattress... but I would love to see what other members are using. Thanks in advance.
mykah is offline   Reply With Quote
Old 10-10-2017, 02:16 PM   #9
storage
front of a 97 CB model
realistically the bunk is really only good for storage..or CATS....LOL
I converted mine to a three compartment "closet" (his, hers and linen)....later turned the doors upside down and installed cargo netting...(spring shocks gone in favor of door latches like the ones found on the horizontal opening doors elsewhere in the trailer)
the free standing divider "thing" is held in place by two small screws....because the latch is no longer accessible I rigged a spring to it (now spring loaded)...with a trip rope (the latch on the left side is not needed or used...although it's accessible...those latches aren't the best...finicky to use/operate... with a spring added they work great)
the drop down panel certainly makes it a snap to load/unload, sort/organize everything before or after a trip
Old 10-10-2017, 03:44 PM   #10
Yes, you will need plywood under the mattress. I also rigged some netting from the ceiling to under the mattress to prevent rolling out of the bunk.
Old 10-10-2017, 05:46 PM   #11
member
Isle of Wight
I have a 2002 Bigfoot 17CB and I cant see any evidence of bunks at either end - just lots of storage. Did they abandon the idea at some point or do I actually have bunks hidden away somewhere....
WizWid is offline   Reply With Quote
Old 10-11-2017, 02:33 PM   #12
Trailer: Bigfoot 17' DLX
Alaska
I had the rear upper bunk in my gaucho model. Pretty useless. My kinds didn't want anything to do with it even though they sleep in a bunk bed in the house. It remained as a storage cabinet the entire time I owned it.
trainjunkie is offline   Reply With Quote
Old 10-11-2017, 08:37 PM   #13
ZachO's Avatar
Trailer: Sasquatch
Montana
Check at the upper outside edges of the front upper cabinets for locks. Pull those and the cabinet face will drop down, if you have bunks.
My biggest issue with them was that they make it hard to access stuff in there. Otherwise I would have left mine as they were. I took out that whole face and made storage and a bookshelf. Francois’ idea, as usual, is a good one.
Old 10-11-2017, 09:04 PM   #14
There have been several threads about Bigfoot bunks and many reply's. This is the first reply I have seen that indicates someone actually using one for sleeping.
Old 10-13-2017, 12:20 PM   #15
Trailer: Bigfoot 17
Quebec
Well... it took couple of nights adjustment for her, and the first thing she asked was for us to raise the roof! (We're making the transition to trailer from pop-up truck camper
bigfoot
Installing a front dinette while retaining bunks, couch and porta-potti in 13' Scamp" Scamper Jim Modifications, Alterations and Updates 100 09-14-2020 02:48 PM
Bring the bunks back Deb H Problem Solving | Owners Helping Owners 29 03-19-2009 07:31 AM
2000 Scamp 16' toilet, bunks, a/c, hot h20,dual propane KirkG Classified Archives 2 07-05-2008 06:27 AM
beefier bunks Peggy Problem Solving | Owners Helping Owners 16 06-26-2007 09:14 PM
