Bigfoot Range Hood Vent - Fiberglass RV
Old 09-26-2018, 12:29 PM   #1
Name: John & Gloria
Trailer: Bigfoot 21RB
The outside vent on my Bigfoot doesn't have a flapper to keep insects and wind out of the RV so I removed the hood over the stove and someone had put a metal piece in the opening held on by duct tape as a hinge at the top. It sat at a bit of an angle and the weight of it is too much for the fan to push open. I am hoping someone here has dealt with this problem already and can give some advice as to how they addressed this. The outside cover is well done and tidy. I am hoping I can keep the same design.
Name:	20180926_140552 (Small).jpg
Name:	20180926_140600 (Small).jpg
Travelin2 is offline   Reply With Quote
Old 09-26-2018, 09:00 PM   #2
My flapper broke. I looked at ordering a replacement cover, but , some were too small, others too big. I contacted Bigfoot and they stated there is not an issue with putting a larger one on, essentially cutting the opening bigger if I so chose. The smaller ones would not cover the holes of the original. Did not want to cut a larger hole because I didn't think, and still don't, that the cut out would match the exhaust vent.
So, what I did is I took some fine mesh screen, patio door stuff, and I cut out a square a little larger than the size of the vent opening. Then I rolled it up and shoved it into the opening.
Then I took a piece of foam carpet padding, not the cheap rebond stuff that falls apart, and I cut a piece that I could stuff up in to block off the vent and easily remove as times warrant.
Works great, minimal expense, and no cutting into my unit.
I don't know if this will work for you, but if so, great!
Bigfoot will sell and ship you a new vent cover if you contact them.
JimKE is offline   Reply With Quote
bigfoot
vent cover for range hood megatrack Problem Solving | Owners Helping Owners 0 03-26-2012 06:31 PM
Boler 1700 range hood Peggy Problem Solving | Owners Helping Owners 2 04-23-2008 05:09 PM
Range vent hood KamperBob Classified Archives 8 08-30-2007 08:35 AM
Range hood MikeyC Problem Solving | Owners Helping Owners 1 07-31-2007 07:33 AM
