13' Boler door- floppy bottom 1/3 - Fiberglass RV
Old 10-01-2014, 07:32 PM   #1
Trailer: 17 ft Boler
Smile 13' Boler door- floppy bottom 1/3
what are the recommendations to reinforce the bottom third of the door....it flops in the wind and hangs partially open when it's parked?
thanx.
Carol & Jon M,
Edmonton, Ab,
FargoEd is offline   Reply With Quote
Old 10-01-2014, 08:02 PM   #2
Carol H's Avatar
Here is a PDF that will give you instructions:
www.fiberglassrv.com/files/BolerDoorFix.PDF
Old 11-09-2014, 09:02 AM   #3
jcstanley's Avatar
Trailer: 30' jayco & 1974 Boler
thanks !! I needed that . John
jcstanley is offline   Reply With Quote
Old 11-09-2014, 10:09 AM   #4
Rick Mooyman's Avatar
Trailer: 1971 Boler
Wow Awesome article I just bookmarked it and printed it for future reference.
Rick
Rick Mooyman is offline   Reply With Quote
Old 11-09-2014, 11:16 AM   #5
Y'all really should spend some time poking around in the Document Center. Tons of great stuff!
Old 11-10-2014, 04:50 PM   #6
jkmboler's Avatar
Trailer: 1974 1300 Boler
Manitoba
Boler door fix
I fixed my floppy lower door on my Boler when we first got it (20 years ago).
My fix took about one hour and solved the problem.
I used stainless steel aircraft cable (1/16"), some small turnbuckels and 3 1/4" stainless bolts and nuts.
I used some fender washers and a grinder to make a teardrop shaped washer with a 1/8" hole to secure the aircraft cable. (this would have been better if the fender washers were stainless steel, but, I couldn't find what I needed when I needed them so... you will see some rust on the washers).
In my case, I was able to use one of the existing fasteners from the door latch and only used 3 1/4" bolts. These 3 1/4" bolts are the only thing visible from the exterior. Use double nuts on the bolts and DO NOT overtighten the bolts, this will crush the door. Snug the bolts up and lock them in place with the double nuts.
The turnbuckels allow for adjusting the tension of the cables and this draws the lower section of the door against the camper and allows the door to seal.
The photos should be self explanitory.
1974 Boler 1300
Manufactured in Winnipeg, Manitoba.
jkmboler is offline   Reply With Quote
boler
Bottom Door Bar Hook? BruceG Problem Solving | Owners Helping Owners 9 03-22-2018 11:13 AM
Scamp/Boler Bottom Door Bar Hook Rick G Care and Feeding of Molded Fiberglass Trailers 26 12-10-2010 06:58 PM
Scamp Bottom Door Bar Hook John Jesse Problem Solving | Owners Helping Owners 15 12-09-2010 12:00 AM
bottom door bar hook Steve M K Problem Solving | Owners Helping Owners 4 08-10-2009 07:20 AM
Floppy door handle Christi V. Problem Solving | Owners Helping Owners 9 04-05-2007 08:40 AM
