Painting the Inside
After a lot of research on the interior Elephant skin lining and trying to get the surface clean and white I came to the conclusion
painting was the only alternative. Researching
paint I found some very interesting information. First was surface preparation, I have always used trisodium phosphate (TSP) as a cleaner but discovered that many paint manufacturers will void their warrantee if it is used. The reason appears to be related to insufficient rinsing which leaves a residue that the paint will not adhere to. The recommended cleaning agent is ammonia and water in a 1:1 ratio. The ammonia water cleaner works very well on oil, grease and stubborn stains, it also does not require rinsing and dries leaving no residue. After cleaning, and with the seam tape removed, all the seams are filled with a paintable latex caulking. I used DAP Dynaflex 230, which is and indoor outdoor caulking that is incredibly easy to work with and offers a 50-year satisfaction guarantee. The entire interior is primed using a high adhesive primer, I used Zinsser Bulls Eye 1-2-3, this is a Rustoleum product that can be used to prime ceramic tile for painting so it should work. Over the primer use a high quality latex paint, I used Rustoleum Painter’s Touch in gloss white. The paint has currently been on for 3 years and I am extremely pleased with the look and durability at this time.
