Scamp & Casita owners, Where did you put your TV? - Fiberglass RV
Old 12-14-2013, 12:01 PM   #1
Trailer: 1997 16' Scamp
Cool Scamp & Casita owners, Where did you put your TV?
Hi,
We own a 16' Scamp and are trying to sort out the best place to mount a TV. The trailer came with an antenna with the hand crank above the dining table. What have others done? How large a TV. Where and how did you mount it? I have some thoughts but would like to be aware of options.
George
varmint is offline   Reply With Quote
Old 12-14-2013, 01:57 PM   #2
Television mount
24" TV. Flip mount. 17'SD
LK Gray is offline   Reply With Quote
Old 12-14-2013, 02:35 PM   #3
Carol H's Avatar
I have a 16' Scamp that I mounted a 19" flat screen in the rear corner. I take it down when traveling. The DVD player is inside the overhead bin.
Old 12-17-2013, 04:47 PM   #4
When I got my Scamp 13 the last owner had a TV mounted on the side of the dresser/cabinet next to the entry door. Seems to be a good location for it as you can watch it whilst sitting the dinette with the table up, or sitting/slouching against the back window with the bed set up.
But I took it out anyway since we're not big on TV watching whilst camping.
Peter L is offline   Reply With Quote
Old 12-17-2013, 06:35 PM   #5
peterh's Avatar
Trailer: 2005 19 ft Scamp 19 ft 5th Wheel
We bought a Coby HDTV/AM/FM/DVD/CD under-cabinet unit. Designed for home kitchen use, it has a 12VDC "wall-wort" adapter that made it very easy to wire it into our trailer's 12V system. Coby sells this unit in a variety of screen sizes, seven to fifteen inches.
We don't watch TV much when we're out with out trailer, so the 10" screen version works just fine for us, and it draws under 2 amps when we're using the DVD/HDTV combo and even less any other time, so it doesn't tax our solar-powered electrical system.
I setup a nylon strap and buckle system that holds the screen in its stowed position while we're towing.
peterh is offline   Reply With Quote
casita, scamp
Burro owners - what to look out for & insulation ???? Gregg E. Care and Feeding of Molded Fiberglass Trailers 5 04-02-2009 06:08 PM
Inside height on Scamp & Casita matt scott Care and Feeding of Molded Fiberglass Trailers 12 03-04-2006 10:05 AM
Casita, Burro or Scamp (16 & 17')... Charles Wright General Chat 11 01-08-2006 06:25 PM
Does Casita put a silicone seal on the bench? Legacy Posts Care and Feeding of Molded Fiberglass Trailers 7 06-25-2003 10:43 PM
Inside height on Scamp & Casita General Chat 0 01-01-1970 12:00 AM
