Uhaul saging door issue - Fiberglass RV
Old 10-14-2018, 06:55 AM   #1
Trailer: In the market
Quebec
Hello guys,
I bought a Uhaul Ct13 and started restoration. Did a lot of work. But i have issues with saging door. Wonder who has experience with that and what wo7ld be the options! Thanks
30047EFE-0005-4002-9458-0260415C4EC4.jpg   D045AACE-99F7-4910-B136-D33AB5BAEAA5.jpg
C6448A94-85E9-4938-8348-A12D582BCFE4.jpg   7D1C554E-0126-478A-A945-AAA8D852DAA3.jpg
Eric berube is offline   Reply With Quote
Old 10-14-2018, 07:24 AM   #2
mmeyer's Avatar
Trailer: U-Haul VT
Indiana
There is some adjustment that can be made wire the striker plate both up and down and in and out. You also should have two guide pins on the lockset to bring the door level. Most have the bottom of the door a little proud of the frame after 30+ years. You will need to slightly loosen the striker bolts and the cabin hinge bolts to adjust. A 1/4” drive ratchet with extension and deep well socket should work for cabin side. Pop the plugs for access. Typically a two person job, one to hold door other works the wrench.
mmeyer is offline   Reply With Quote
Old 10-14-2018, 07:50 AM   #3
Not the best pictures to see amount of sag. You need to look at the variation in the gap across the top and down the sides, is the gap even on the sides and top or does it change from one end to the other. From what I can see it looks fairly even across the top. Are you more concerned about the bottom of the door not fitting tight. A photo looking straight on to the door would help, plus one of the end of the latch. If you are not familiar with what the guide pins look like you may not know if they are there or not.
Old 10-14-2018, 10:55 AM   #4
Trailer: G30 Elite Class C
Originally Posted by Eric berube View Post
Hello guys,
retty hard to see the problem when all the pictures are upside down and you do not exactly show the door area problem.
stude
Old 10-14-2018, 11:34 AM   #5
How about "SAGGING"? Saging is pronounced Sage-ing
Old 10-14-2018, 02:11 PM   #6
Quebec
What???
Old 10-14-2018, 03:38 PM   #7
mmeyer's Avatar
Trailer: U-Haul VT
Indiana
What???
You might want to join the UHaul Camper Facebook group. They really don’t care how you spell or post things and have first hand experience with all things UHaul.
Old 10-14-2018, 03:49 PM   #8
Quebec
What???
I would presume that he was making a joke. Being french canadian, I consider myself ahead of someone who would only speak english. Meaning that inwould not care much if someone whommake. A gramatical error in french if he were english speaking first. Than again, I am sure this was a joke! And yes, i will also be joining the FB. More is better.
uhaul
Scamp Door Repair Issue Sohkraites Problem Solving | Owners Helping Owners 5 07-15-2022 08:55 AM
Uhaul bunk issue. Need ideas! Brandiwhne Problem Solving | Owners Helping Owners 1 03-03-2014 04:21 AM
Uhaul trailer brake lights issue Astrid N Care and Feeding of Molded Fiberglass Trailers 15 10-03-2011 09:12 AM
