Originally Posted by hjk
Can anyone provide me with the dimensions of the space under the rear dinette of a 13' (big bed w/bath)) Scamp. I want to make sure that the dog bed will fit in that space
You don't say whether you have a Standard or Deluxe.
The Deluxe is 30"W X 54"D X14.5"H
On the Standard the Width will be Approximately 1"to1.5" less due to the fact that the bench is molded straight down from the bed platform notch.
The Space in question will not be quite as Deep at the bottom either due to the curvature of the back wall, both vertical and horizontally.
So A good guess for workable space would be say... 28"W X 48"D X 14"H
The Height will be further reduced by the table hardware... maybe by as much as an inch.
Another consideration...
I remodeled a 13Scamp Standard with a permanent bed with space below which you describe to provide room for two smallish dogs.
To make room for pets, you must also consider that the table hardware may present issues for accommodation of pets. This hardware may reduce the height of the space by a small margin.Also it could present an injury hazard.
I removed the table and replaced it with smooth epoxy coated plywood which made the space safer and more comfortable for the pets. or for under the bed storage.
