Scamp Coaxial Metal End Cap with Chain and Ring - Fiberglass RV
Old 06-29-2019, 06:44 AM   #1
CampyTime's Avatar
Trailer: Scamp 13' Standard
Hello, I see I've lost my coax cap in travel from storage. The ring that slides over the coax port had been disintegrating...no wonder. I have a 2012 Scamp 13.
I can't find the right part anywhere, believe it or not. Does anybody know what company makes the right end cap, with the metal ring that fits over the coax port, and chain?
Grateful for your help,
Wendy
Old 06-29-2019, 07:44 AM   #2
NW Wisconsin
I assume you are referring to the metal connector on the end of the coax cable
The cable connectors are available at HD , Menards , Lowes and most good hardware stores. There are two styles — crimp on and screw on and you need to get the right size for the cable you are using (RG 6?)
The crimp on ends require a crimping tool to lock the end to the cable
It’s a simple task and instructions are supplied with the connectors
I keep a couple spare in my trailer and just replace them as necessary
Old 06-29-2019, 12:28 PM   #3
GOB
Trailer: Scamp 19
Missouri
Coax cap
You can find them on ebay but they come 10 or more to a pack. I just found an old piece of coax and cut one end off.
GOB is offline   Reply With Quote
Old 06-29-2019, 01:38 PM   #4
mszabo's Avatar
Trailer: U-Haul VT16
https://smile.amazon.com/JR-Products...6W8Z35TQ7YZF56
mszabo is offline   Reply With Quote
Old 06-29-2019, 02:05 PM   #5
I think Mike has it right, Wendy is missing the dust cap, is how I interpret the question.
Old 06-30-2019, 12:41 AM   #6
David B.'s Avatar
Wendy
Custom Cable Group LLC sells them two to a pack for less than $9.00 on Amazon
They have the metal cap/chain/ring combo.
Old 07-01-2019, 06:33 AM   #7
CampyTime's Avatar
Thank you, I just found the RG6 size screw on cap, with O ring. Bought a ten pack, but believe it or not, was cheaper than a 4 pack. Many different sizes out there...Type N, F. Mine is an F size apparently. Thanks again!
Old 07-01-2019, 07:25 PM   #8
Trailer: Damon
[QUOTE=CampyTime;746965]Hello, I see I've lost my coax cap in travel from storage. The ring that slides over the coax port had been disintegrating...no wonder. I have a 2012 Scamp 13.
Wendy[/QUOTE
just slip a 1/2 " of those little ball chain things they use on light switches into a regular coax nut hot glue and cut to length. Hot glue again. Voila!!
workhorsed is offline   Reply With Quote
use coaxial connection for cell boosting? ianmcadams Electrical | Charging, Systems, Solar and Generators 2 07-07-2018 07:12 AM
End Cap for sewer hose storage tube Steve Hammel Plumbing | Systems and Fixtures 5 06-24-2013 06:53 PM
Snap cap/Button cap question Kevin K Problem Solving | Owners Helping Owners 5 06-19-2012 11:50 AM
Grease Leaking from Metal End Cap on 2005 Scamp 5th Wheel jcellis54 Towing, Hitching, Axles and Running Gear 11 03-09-2012 01:49 AM
"Original" Trillium Factory KEY RING/CHAIN? Dave Baston General Chat 0 06-09-2010 04:53 PM
