inside of scamp 13' - Fiberglass RV
Old 07-10-2019, 09:59 AM   #1
Trailer: Scamp 13'
inside of scamp 13'
Im am almost ready to line the inside walls of my little 13' scamp. any suggestions on what is the best thing to use. I would appreciate any help.. thanks Margie
Margie Lewis is offline   Reply With Quote
Old 07-10-2019, 10:21 AM   #2
What do you mean? Does it not have wall covering already (rat fur or elephant hide)? Are you rebuilding it? Or are you just talking about decorating.. in which case I suggest putting nothing on the wall.
Old 07-10-2019, 10:29 AM   #3
Trailer: Scamp 13'
rebuilding it, right now it only has the floor put back in it.. ready to think of what to use for the walls..
Old 07-10-2019, 10:34 AM   #4
I would sure go with the same thing that all current day Scamps have.. Reflectix® type insulation and marine headliner. Both can be sourced from Scamp (Evelands) or elsewhere.
I would also read up a lot about how to go about it from people who have done it - apparently its hard to get the cuts right. I do recall that if you are removing it, it was suggested to save the old pieces as a template. I guess it would be too late for you now.
Old 07-10-2019, 10:43 AM   #5
Trailer: Scamp 13'
I will be using the Reflectix just not sure what to use over that. I did not have a pattern. Sure wish I did, the rounded corners are what Im worried about. what ever I use will have to have some stretch in it to make it look right, at least thats what i'm thinking.
Old 07-10-2019, 11:05 AM   #6
Sound reducing, highly mold and mildew resistant, soft to the touch, fairly easy to cut. What else could you want? Headliner
But elastic it is not.
Old 07-10-2019, 03:50 PM   #7
Trailer: 2000 16ft Scamp
Minnesota
Idea
Have you called Scamp and see if they would sell you the pieces to fit your 13 footer? They have always been accommodating when they can.
Good luck!
John
The earth without art is just eh....
crowwing is offline   Reply With Quote
Old 07-10-2019, 04:04 PM   #8
Good luck!
John
Yes they will (shipping might be a bit much).. the word "Headliner" in my prior post is a link to the rat fur in the Scamp store.
Old 07-10-2019, 05:09 PM   #9
Jon in AZ's Avatar
inside of scamp 13'
There are marine headliner products with less “fuzz” and different colors (mostly shades of beige and grey neutrals) online or through a local marine upholstery shop. I’d personally go with something a bit smoother.
I camp with three females, and the rat fur tends to collect hair. A minor issue, really. Overall I’m very happy with the performance of the factory lining. But if I were redoing the interior lining...
Old 07-11-2019, 08:46 AM   #10
Trailer: Scamp 13'
No I have not called Scamp but thanks, Sounds like a great idea. I will call them. Margie
Old 07-17-2019, 12:25 PM   #11
Trailer: Currently Shopping
South Carolina
Lining trailer
I’d use foam to insulate your trailer and dampen sounds as well.
John Lamendola is offline   Reply With Quote
Old 07-17-2019, 01:29 PM   #12
Jon in AZ's Avatar
Closed cell foam is a good lining, but without a topping of some kind, it is soft and easily damaged. Ensolite (no longer made) had a bonded top layer of textured vinyl that made an extremely durable shell lining.
Escape is using a similar product with a smooth vinyl top layer, but I’ve never heard where they get it, possibly a marine supplier.
Closed cell foam is trickier to install than the foil bubble/headliner sandwich used by Scamp and others, but the end result is effective, durable, and easy to clean.
Old 07-17-2019, 02:47 PM   #13
Alex Adams's Avatar
Trailer: 1979 Boler B1300
New Hampshire
Actually Ensolite is still being made. You can get it faced or not faced. You just can't get the version with the "elephant skin" facing.
It's not cheap though:
https://foammart.com/product/ensolite/
https://www.professionalplastics.com...ITEPVC-NBRFAOM
https://scs-interiors.com/products/e...t-raw-material
Old 07-17-2019, 03:28 PM   #14
Jon in AZ's Avatar
Interesting. I knew a similar product was still being made, but I didn't know it carried the trademark Ensolite name. I assume it's now being made by other companies under license.
Unfortunately, it is faced in black vinyl. Looks like that's the only choice.
Old 07-17-2019, 10:15 PM   #15
Alex Adams's Avatar
New Hampshire
It also comes without facing. You can always glue "rat fur" on top of it.
I suspect it would have a higher R rating than the Reflectix, though probably not much higher.
Old 07-18-2019, 12:53 AM   #16
Jon in AZ's Avatar
For the cost and ease of installation, I’ll just stick with Reflectix. It’s a hack, but it seems to work reasonably well in practice.
Repair Scuffed Inside Fiberglass - Scamp Raunie Aasland Problem Solving | Owners Helping Owners 1 09-02-2007 03:00 PM
Scamp 13 Remod is almost done-inside Gary Carvajal Modifications, Alterations and Updates 7 01-01-2007 08:53 PM
Inside height on Scamp & Casita matt scott Care and Feeding of Molded Fiberglass Trailers 12 03-04-2006 10:05 AM
Inside height on Scamp & Casita General Chat 0 01-01-1970 12:00 AM
Inside a Scamp 5th Wheel General Chat 0 01-01-1970 12:00 AM
