Scamp 16 foot side dinette loose screws - Fiberglass RV
Old 07-12-2019, 09:23 AM   #1
The bottom screw came out of bottom right side of bathroom door trim.
There is no way to put one back in because I can not get a screw to start using the hole visible in the trim.
It hits what seems to be a cast iron wall and even trying to angle the screw does nothing.
By the way ALL of the screws keep falling out ALL the time. I have replaced them with longer and larger except this one is not co-operating at all.
Gary Smigs is offline   Reply With Quote
Old 07-12-2019, 10:51 AM   #2
NW Wisconsin
Try putting a dab of gorrila glue on the screw threads
I removed all the screws in my Scamp , applied glue , never had another screw fall out
Old 07-12-2019, 01:03 PM   #3
DougOlson's Avatar
Trailer: Escape
Yes, when a bit of glue no longer works I replace the ones I can with stainless steel bolts; moulding around bathroom door, furnace vent, side dinette base attached to floor. I'm sure there will be more. Scamp's a nice trailer for people who like to fiddle with things. [emoji4]
DougOlson is offline   Reply With Quote
Old 07-13-2019, 05:44 AM   #4
Thank you for the suggestion. I will remember that for when the longer screws work loose. My biggest concern now is why I can't get a screw in the bottom right hole of the bathroom door trim. I have no clue what the screw is hitting. The one on the left bottom did not fall out completely and tightened up but all there is on the right is a hole where I assume a screw used to be.
Old 07-13-2019, 09:14 AM   #5
Trailer: '06 Scamp 16
Rochester, New York
Unbalanced tires will also cause screws to loosen on the road. Follow the suggestions to reinstall with glue and make sure tires are balanced.
Lynn Eberhardt is offline   Reply With Quote
Old 07-14-2019, 07:46 AM   #6
Paul O.'s Avatar
Is it possible that the screw broke and a piece of it is stuck inside? In that case, unfortunately, the replacement would have to fit next to it at a slight angle. Or, a shorter one, secured with epoxy putty (plumber's putty). Just some thoughts.
Old 07-14-2019, 08:19 AM   #7
That was my first thought so tried to angle screw resulting in just massacreing the hole in the trim piece. I thought maybe a knot but have not seen any real wood in my Scamp that I didn't bring in so maybe there is steel behind there. I figure not super important but still would like to know, ha.
Old 07-27-2019, 01:19 PM   #8
Radar1's Avatar
Trailer: 2005 16 ft Scamp Side Dinette and 2005 Fleetwood (Coleman) Taos pop-up / 2004 Dodge Dakota QuadCab and 2008 Subaru Outback
If it's the screw at the bottom of the vertical trim piece, I discovered after several loose screws at that point that it doesn't actually screw into wood. That one actually goes through the wood trim, and then the sheet metal framework in the front, and is visible from underneath the camper. I substituted a sheet metal screw there with a nylok nut on the other end outside the camper. Hasn't come loose since.
The screws under our sink on our 16' side dinette model used to always come loose. The biggest problem with those is that they are screwed into the edge of the OSB and that can actually make the OSB separate since they tend to pry it apart. For some of those screws, I drilled vertical holes on the inside and inserted small nuts and bolts with wide washers to compress the OSB back together (after squirting some wood glue into the screw hole) and that seems to hold the screws tighter. Bigger screws just tend to split the OSB even more.
Dave (and Marilyn who is now watching from above)
Sharpsburg, GA
04 Dodge Dakota V-8, 17 Dodge Durango V-6, 19 Ford Ranger 2.3 Ecoboost
radar1-scamping.blogspot.com
Radar1 is offline   Reply With Quote
Old 07-27-2019, 09:55 PM   #9
Ohio
Interesting thread. What is OSB. I don't want mine splitting.
Tony D is offline   Reply With Quote
Old 07-27-2019, 10:10 PM   #10
Glenn Baglo's Avatar
Oriented Strand Board. Google likely has pix and info.
Old 07-27-2019, 10:31 PM   #11
Ohio
Got it. The floor board is made from OSB not plywood. Thanks
Old 07-28-2019, 02:40 PM   #12
this is to radar, can't figure out the reply function on the app to individual posts
it is the bottom screw and I had an idea it must be hitting metal. It was also the only "hole" I did not find a corresponding screw to. Most just backed out some, a couple were on the floor, but all I found after looking was a hole in the trim, so not sure what type of fastener was used there. Thanks for the direction, because with the shower being on the other side I didn't want to mess up.
Sleeping on the side dinette? Front dinette? Lorrie General Chat 21 07-18-2018 09:27 PM
Casita screen door screws loose sjrayfie Problem Solving | Owners Helping Owners 8 03-12-2018 12:41 AM
Loose screws in 2015 Scamp bath door DougOlson Care and Feeding of Molded Fiberglass Trailers 31 06-23-2016 11:37 AM
2004 Scamp 16 foot side dinette Ontario, Canada Paul MacDonald Classified Archives 4 07-17-2011 11:18 AM
