1981 Bigfoot - Fiberglass RV
Old 06-23-2017, 12:01 PM   #1
Trailer: Big Foot
1981 Bigfoot
Hi - I'm a new member and a happy camper. Just bought a 1981 Bigfoot trailer. Previous owner had taken out the benches in the dining nook. The table is still there. We want to put the benches back in, along with the cushions to be able to have a bed there. Can anyone give me the dimensions of the bench, along with the cushion dimensions?
Also, they made a permanent bed (for the bed on the left as you enter) - they nailed a board in the gap of the couch. Can anyone tell me how the sections should go together?
anjablake is offline   Reply With Quote
Old 06-23-2017, 02:12 PM   #2
congrats.....
I have a 97...there might just be small differences in the measurements given the 17 year difference but if the left side storage cabinet (first picture below) looks the same you can start with this because the shells would be identical....(all in inches)
cushion seats.....41 x 20 x 4
cushion seatbacks....41 x 20 x 4
distance from floor to top of plywood seat....14.25
table is 31" wide and that is the distance between the two seats
Look at how the seats and seatbacks are laid out sitting there and that will give you all other dimensions
the rear bed sounds simple...remove the added ply and nails and the section of bed should then be free to slide to the folded in position (gaucho)
(pics below shows my table stowed upright against the bulkhead....table is also two inches shorter than stock)
good luck....
Old 06-23-2017, 02:24 PM   #3
on second thought....
81 might be different interior construction/cabinetry.....hopefully somebody with a 79 to 87 (or so) model year will respond....
as a side note if there is nothing there now...let your imagination run wild ...some people have made the front as a permanent bed and use a fold up table at the gaucho to eat at......put your thinking cap on
where you at in BC?
Old 06-24-2017, 01:29 PM   #4
Trailer: Big Foot
Thanks Franswa!!
Thanx for your info - I think the dimensions are different on the 81 but good to know the depth of the cushions. I'm in Salmo, B.C.
Old 07-14-2017, 12:12 PM   #5
Kenny Strong's Avatar
Utah
what length is your egg ?
Kenny Strong is offline   Reply With Quote
Old 07-18-2017, 04:42 PM   #6
Trailer: 1983 BigFoot B17
measurements
Hi,
We own a 1983 Bigfoot in the same length. When I get home tonight I will measure the bench and cushions.
Rachel
keenie82 is offline   Reply With Quote
Old 07-18-2017, 07:06 PM   #7
Bigfoot Dimensions
Hi,
I will start with the cushions. This is for the cushion that you rest your back against on bench 1 closest to the fridge.
44 inches long on one side
43 inches long on the other side
10 inches wide
4 inches thick
(This cushion tapers at the end as the wall near the big picture window by the table is slanted)
The cushion that your bum sits on bench 1 closest to the fridge.
42 inches long
21 inches wide
4 inches thick
The other bench 2 that is closest to the door.
The cushion you rest your back against is interesting as it is sewed together so it is 2 cushions in 1.
1 side: 43 inches long on one side
42 inches long on the other side
4 inches thick
10.5 inches wide
again this part of the cushion tapers
2 side: 43 inches long
4 inches thick
10.5 inches wide
The are sewn together so the end of the cushion with the two tapers looks like an arrow.
The cushion on bench 2 that you rest your bum on is:
42 inches long
26 inches wide
4 inches thick
Each of the bench measurements
Bench 1 by the window
43 inches long
21.5 inches wide
14.5 inches tall
Bench 2 by the door
42 inches long
26 inches wide
14.inches thick
Old 07-26-2017, 10:29 PM   #8
Trailer: Big Foot
17 foot 1981 Bigfoot battery placement
I hadn't checked the thread for awhile - thankyou so much for all the dimensions Rachel - we're just at the point of doing that part of our reno... We kinda had an idea of putting it together but your measurements are fantastic!!!! What a great forum!!!
There was no battery in the trailer when we bought it so we bought a marine battery but not sure where it's supposed to go???
Old 07-26-2017, 10:58 PM   #9
typically....
out of the factory, the battery would have been located on the tounge, just ahead of the two propane tanks....
pictures would help...have fun
Old 07-27-2017, 04:29 PM   #10
Glad to have helped Anja. You will have to post some photos!
Old 07-31-2017, 01:01 PM   #11
Utah
battery
try to get a gas mat battery.
bigfoot
Bigfoot Trailer 1981 17 foot gaucho model for sale Pat B Classified Archives 12 01-23-2011 04:59 PM
1981 Bigfoot 17ft roof strengthening Kris St. Jean Problem Solving | Owners Helping Owners 7 01-02-2010 02:08 AM
1981 Bigfoot 17fter $3750 Robin G Classified Archives 4 10-17-2009 08:46 PM
1981 bigfoot battery charger? Kris St. Jean Problem Solving | Owners Helping Owners 0 09-15-2009 09:47 AM
Roof air for a 1981 17' Bigfoot GHYNES Problem Solving | Owners Helping Owners 1 09-13-2009 04:14 PM
