07-26-2019, 08:15 PM
#121
Trailer: 13 ft Boler
Great to see progress! Do you think the trailer has enough self support without the cabinets etc now that you have put in all that ribbing?
What colour have you decided on?
Too bad about the door shape change but looks like you have it covered.
Great work, looking forward to the finished product now.
Fred
07-26-2019, 08:24 PM
#122
Trailer: 1975 13' Boler
Hi Fred, thanks Yes, the whole trailer is very rigid now with the panels glued in...seems very strong! The bottom will be teal and the door/top will be a soft white. I'm really looking forward to seeing it painted and then on to cabinets...that's what I've been waiting for!!
08-21-2019, 03:54 PM
#123
Awesome set of posts cannot wait to see more of the final product
08-25-2019, 11:03 AM
#124
Trailer: boler
Originally Posted by Shanos
I also received the baggage doors. They aren't very big but will allow access to storage of smaller items in a space that would be very cumbersome to reach from the inside. It's all about maximizing space in these small trailers!
Awesome job so far. I am doing a small reno on my boler but not going as in depth as you have. Two questions. 1. What size is your baggage door and where did you get it? 2. I also have new windows from Sunview, do I need a plywood frame to install them. didn't get any instructions on installation. My ensolite is in good shape and I want to keep it, have a little left over from the window above stove I will use to patch the new radius corners, will caulk the seams.
08-27-2019, 08:21 AM
#125
Hi Nancy, sorry for the tardy reply. You shouldn't need a plywood frame to install the windows. I haven't installed mine yet (very soon) but the window and trim ring are meant to basically "sandwich" the fibreglass and ensolite (you would have been asked for the wall thickness when you ordered your windows). And yes, there are no installation instructions given. As I see it, screw the trim ring into the window and that should squeeze tight enough to hold in place. They supply foam gasket but I will be using butyl tape...much longer lasting and I am trusting it more to seal than the foam. If you check out boler-camping.com and go to "fixing leaks - windows and vent", Ian does a good job of explaining the difference between a good and poor quality of butyl tape.
My baggage doors came from Vision Manufacturing, also in Summerland. Vision Manufacturing and Sunview Industries are two divisions of the same company I believe. The contact person I dealt with was Chris Plowman. My baggage doors were 8 1/2" high x 14" long
09-02-2019, 02:03 PM
#126
Back from the body shop with primer and a pink guide coat!! Really happy with the quality of work done. Very labour intensive grinding out and filling the numerous spider cracks in the body. Back to me to finish a bit of panelling inside then back to the body shop to fill and fare seams, screw holes etc in the panelling. Then the last sand and final prep before the top coats outside! Really starting to see the light at the end of this very long tunnel
09-16-2019, 06:20 PM
#127
At last!! I installed the last pieces of panelling!! Towed back to Mike's Quality Bodyworks to have the seams, screw holes and low spots filled in the panelling and then onto the final prep and painting of the exterior. Very exciting step! Windows, door and ceiling vent/fan can then be installed for a sealed up Boler at long last!! Just in time for the rainy season here
10-07-2019, 09:31 AM
#128
A lot of work to finally get to this point....a pretty spiffy looking Boler!! So pleased with the retro colour! Now onto installing door gasket, final door fitting and seal everything up with windows, ceiling fan/vent and baggage doors.
10-07-2019, 10:33 AM
#129
Trailer: Sold it
Northern VA
Great paint job! Love the colors.
So I take it it's regular auto paint?
Sold the burro
10-07-2019, 03:09 PM
#130
Very nice job so far... You have more patience and talent then myself.
10-08-2019, 08:29 AM
#131
Hi Daniel, Thank you! Yes, it's automotive paint with a clear coat on top
10-08-2019, 08:32 AM
#132
Hi Bill,
Thank you for your kind words. This project has truly tested my patience and problem solving skills. Looking forward to the more straight forward cabinet making over the winter.
10-08-2019, 11:41 AM
#133
Out of curiosity, how long was the shell sitting without any inner supports? Im curious as to how long a shell can sit without experiencing any warping issues.
10-09-2019, 08:10 AM
#134
Hi Joseph,
It was years that there were no supports inside the shell but I believe the kink in the door frame happened quite early on. If you are planning on taking components out, I can strongly recommend, at the least, putting in vertical supports to hold the roof up and something to support the doorframe/walls near the door opening. That's where it's really vulnerable. It created a lot of problems for me.
10-09-2019, 09:30 AM
#135
Love the colour combo!
Looking forward to your interior build.
10-26-2019, 05:54 PM
#136
Trailer: Boler 1300
That is a beautiful looking paint job! I like the tail lights too!
10-28-2019, 09:48 AM
#137
Thanks Jay! Hoping to get it "buttoned up" this week with the windows, doors and through hull fittings. Then on to the interior!
01-02-2020, 05:07 PM
#138
Trailer: 1975 Triple E Surfside
Looking good... I'm working on the scamp too this winter...
I did not want to take the two halves apart so the body was rolled and slid on carpet into the shop.. Need to glass in the floor.
02-01-2020, 11:48 PM
#139
Forgot to mention, love the colours!
02-06-2020, 08:25 AM
#140
Thanks Randy!
Currently Active Users Viewing This Thread: 2 (0 members and 2 guests)
