Carpet & Headliner Replacement help - New Burro Owner! - Fiberglass RV
Old 02-24-2012, 10:50 PM   #1
Trailer: New Burro Owner
Headliner Replacement in Burro - New Owner - Help!
Just bought my Burro & am happy as can be! The little guy is in pretty terrific condition but the carpet & the fabric on the ceiling has got to go.
1) So... what is the fabric that is currently up on the center of the ceiling called (kind of like a furry, matted carpet)? Mine is a nasty blue color & I'd like to put a red/burgundy contrast stripe in this area.
What else can i use to cover this area (what kind of carpet/coverings have others tried)? Also, do I need to cover this area with insulation first?
What is the best adhesive to get "stuff" to stick up there?
2) Any suggestions for replacing the carpet? Should I put foam padding down? Do i simply glue this stuff in place or do I need to tack it down like wall-to-wall in a house?
Sorry for the novice questions but I really want to do this right (read: Hate to have to recreate the wheel when I believe a number of you are "wheel" experts!)
Thanks in advance for your time & help!
BTW: I bought the burro from the guy in Texas who had the posting here. It was only 22 miles away from my home (no road trip to Vancouver or Oregon -- yea!!) & was everything he said it was. Super great guy to deal with -- honest & helpful. The 13" Burro cost me $4500 in case anyone was wondering what his "reasonable offer" arena was...
Armymomma is offline   Reply With Quote
Old 02-25-2012, 01:08 AM   #2
LukeP's Avatar
Trailer: 1972 13 ft Boler American
Congrats! You can use the google search function for all kinds of threads on options and opinions of this very subject on these forums. Here is my experience:
1) I removed the old carpeting, scraped my fiberglass clean. Then used Reflectix (double sided bubble style insulation purchased at Lowes http://www.reflectixinc.com/basepage.asp?pageIndex=729#ReflectiveInsulations) glued with a Landau High Heat Resistant adhesive (there are threads on here discussing different areas of the country's heat/humidity having good/bad luck with many different adhesives/sprays/glues. 3M 77 or 3M90 have had mixed results depending on climate. You can also read these discussions on auto headliner forums) then used a marine carpet as a headliner... flexible for the curves of the trailer. If you're going to the effort of putting up new headliner - I'd highly recommend insulation. My trailer didn't have any before and it's helped keep it cooler/warmer since I re-did it.
2) I didn't use carpet as I wanted a hard surface, so can't help you on this one.
Good luck!
LukeP is offline   Reply With Quote
Old 02-25-2012, 03:59 AM   #3
Thomas G.'s Avatar
Did we post the same question twice?
Old 02-25-2012, 04:04 AM   #4
I did ... Wasn't sure which forum was the most appropriate so I posted on the 2 that seemed like relevant headings. Is this verboten? My apologies if so!
Old 02-25-2012, 04:39 AM   #5
Thomas G.'s Avatar
It isn't tidy.
Old 02-25-2012, 12:00 PM   #6
I've asked the moderators to merge the two threads together.
I don't have a vertical seam trailer, but always liked what Mike did using bamboo in his Burro. You could do the same in yours. Or use something else that you like, but this may give you some ideas.
http://www.fiberglassrv.com/forums/f...ior-46625.html
Old 02-25-2012, 01:09 PM   #7
cpaharley2008's Avatar
done
Old 02-26-2012, 01:00 PM   #8
Talking Replacing Flooring w/ Vinyl Faux Wood Question...?
Thanks for all the help! This is a terrific resource -- I really appreciate being pointed in the right direction for the headliner replacement
Another question: Looks like I'm leaning toward the faux wood laminate (will put throw rugs on top to shake out dirt, etc so will have the best of both worlds -- sweeping & shaking -- hopefully!). I found some at Lowe's last evening that would work great.
So...When I put this in, should I be looking at laying it straight on the existing floor or will I need to add an additional surface to adhere it to? I've read that some folks have put new flooring materials in on top of the existing carpet (don't want to do this) & some have put in a 1/4 plywood base & then tacked the vinyl down.
I haven't torn the carpet up yet so I'm not 100% sure how much gunk/old glue is down there. Just wondering if there is a base substrate that needs to go down so that the Vinyl flooring lies smooth...?
Thanks again for the help -- much appreciated!!!
Old 02-26-2012, 07:38 PM   #9
jen b's Avatar
Trailer: 1980 13 ft. burro
Candace, congratulations on your new burro! I'm in the middle of a total re-do of mine. For the headliner thing, for this round I'm planning to stick yoga mats up there. Being closed-cell foam they essentially are insulation that doesn't need extra dressing. They come in a whole range of colors (with goofy color names like chai and ocean ) and thicknesses. I'm not sure what year your Burro is/how wide the interior ceiling gap is, but mine is about 23 inches give or take - the yoga mats generally are 24, and once you jam it up to the ceiling peak, that pretty much takes up the whole width of the mat.
jen b is offline   Reply With Quote
Old 02-26-2012, 08:04 PM   #10
Pam Garlow's Avatar
Trailer: U-Haul 1985
I tore down the carpet and glued up reflectix with a natural grasscloth shade material spray-glued to it. The grasscloth can be cut with scissors. Then I finished off the edges with a decorative trim that I hot glued onto it. I bought an extra shade in case I decide to finish the area under my windows. You have a lot of choices beyond carpet, including material, vinyl, thin bendable wood, matchstick blinds, etc.
Pam Garlow is offline   Reply With Quote
Old 02-26-2012, 08:11 PM   #11
You will need to tear out the carpet to determine the floor condition underneath. There maybe glue patches that may have to be removed or sanded smooth. Generally a floating wood floor can be installed over plywood sub flooring. It does not have to be perfectly smooth, but clean and any staples or nails removed. I painted mine first to make it consistent. If you want tile you can install with glue over the cleaned subfloor, just make sure there are no seams or wide cracks.
Old 03-18-2012, 09:01 AM   #12
Thee Jimbo's Avatar
Trailer: 1971 Trails West Campster/1980 Scamp 13
Can I ask what you used, I want some thing easy to clean/wipe down, as I see mine getting very very dusty, and I dont think carpeted walls and ceiling would be that easy to get all that dust out of.
Thee Jimbo is offline   Reply With Quote
Old 03-18-2012, 01:39 PM   #13
LukeP's Avatar
I was referring to the original posters question on carpeting the floor. I used marine carpet on the walls/ceiling and have had no issue with vacuuming the dust out... but that's all relative depending on camping conditions comparable to yours.
If you were meaning the floor surface - I used an industrial tile so it'd take the beating and be cleanable Standard Excelon MultiColor by Armstrong
Sorry if this isn't answering your question!
Old 10-25-2015, 10:26 PM   #14
Trailer: Burro
Hi Jen,
I am a new Burro owner and was curious how your Yoga matts on the roof solution worked out. Are they still up there? Any issues? What kind of glue did you use?
Tom
Tommy Gun is offline   Reply With Quote
Old 02-17-2016, 08:32 AM   #15
Trailer: Burro
Replacing burro headliner
Just replaced mine, with the help of a friend who does wall papering for a living.
Used Reflectix, with contact cememt in 2 pieces- relatively easy.
Bought indoor / outdoor carpeting from Home Depot. 6X8 precut piece.
Put it up in two pieces and was glad to have the "experts" help. When you get to the curves it has to be cut to relieve the crinkles. Goes together and you cant see the cuts-friend knew exactly how to do this. I would have ended up with big wrinkles, and later would have cut them to make it smooth.
I've done a lot of building, but this was a technical challenge.
I'd like to trim the edges, but not sure what to use. Don't like the idea of using screws into the fiberglas, so,will check craft stores for some cloth ribbon to glue along the edges.
Any ideas anyone?
Burroman is offline   Reply With Quote
Old 02-17-2016, 11:47 AM   #16
Trailer: Burro
I used the plastic edging from bathroom wall material (like whiteboard). I had to epoxy it in place, but it looks good and I left a gap for strip led lighting. Click image for larger version
Name:	ImageUploadedByFiberglass RV1455731198.407274.jpg
ID:	92628. I don't have a picture with the lights but it works quite well.
'79 Burro, Rochester NY
samuelm is offline   Reply With Quote
Old 02-19-2016, 06:27 AM   #17
Trailer: Burro
Will check trim idea
ThanksAn idea I hadn't considered.
Will look into it.
Old 04-29-2016, 08:34 AM   #18
Trailer: Burro
Ceiling light
An unexpected byproduct of the indoor/outdoor headliner is that Velcro sticks to it very well.
I glued two small pieces of Velcro to the top of a LUCI solar inflatable light and it illuminates the area over the table so well I could read for hours.
Saved trailer battery. 5 days of camping and used trailer lights for 20 minutes.
Old 06-22-2016, 03:59 PM   #19
Trailer: 1975 Trillium
Good luck!
What did you use for your hard surface
openthegates is offline   Reply With Quote
Old 07-22-2016, 09:25 PM   #20
Luke, what did you use after the reflexit?
burro
Headliner Replacement in Burro - New Owner - Help! Armymomma Modifications, Alterations and Updates 1 02-25-2012 01:08 AM
Burro "Headliner"issues Edward83burro Problem Solving | Owners Helping Owners 11 08-23-2011 08:14 AM
Burro headliner with LED strip kyle minor Modifications, Alterations and Updates 10 07-12-2010 04:42 PM
casita carpet replacement Ted Schmidt Care and Feeding of Molded Fiberglass Trailers 9 08-17-2009 09:57 AM
Overhead carpet replacement Jim C. Problem Solving | Owners Helping Owners 7 04-25-2006 07:11 AM
» Trailer Showcase
Betty
KentH
BFD
Lilliv
