1983 Burro 13r axle replacement - Fiberglass RV
Old 04-06-2016, 04:35 PM   #1
Alan C.'s Avatar
Trailer: 1983 Burro 13r
Kansas
Going to replace axle on my 83 Burro with Dexter. The guy doing the work is perplexed by the torsion suspension facing forward. The local Dexter dealer is saying that Dexter won't warranty the axle if it's installed this way. Is this peculiar to Burro or common practice for this era of egg? Existing axle is only 1,200 lb. capacity, but intend upping that to 1,800-2,000 lb. I would greatly appreciate any advice on this axle project.
Alan C. is offline   Reply With Quote
Old 04-07-2016, 09:21 AM   #2
Trailer: 1980 Burro, 1973 Trillium 1300, 1977 Surfside 14',1975 Boler 13'
Hi there, the rear facing axel is common on some of the old trailers. I have replace both a boler and burro axel that were like that. I reversed both of them and replaced with flexiride axels. Slightly more expensive but they have an adjustable ride angle so if you like a bit higher ride you can get it. As long as the wheel is centered on the wheel well changing the direction of the torsion to the "correct " direction should only make the ride better.
Azur
Azurko is offline   Reply With Quote
Old 04-07-2016, 10:15 AM   #3
bullfrogeh's Avatar
I'd consider asking the opinion of another axle merchant. Ours had considerable RV experience, and knowledgeably adjusted the brakes for our new Dexter axle, to match the original forward-armed Boler axle.
Find yourself; and then others will find you.
bullfrogeh is offline   Reply With Quote
Old 04-07-2016, 10:22 AM   #4
John Colangelo's Avatar
Trailer: Burro, HELIO
Axle Replacement
Make sure you spend a little extra and buy an axle with trailer brakes installed. You'll be glad you did!
Think Positive Thoughts...........
Happy Trails, Life is Short....Camp Often!
John
John Colangelo is offline   Reply With Quote
Old 04-07-2016, 03:09 PM   #5
Alan C.'s Avatar
Kansas
Thanks for the advice, but I have been pulling this Burro all over the western states for 20 years without trailer brakes. Never a problem.
Old 04-07-2016, 03:14 PM   #6
Alan C.'s Avatar
Kansas
Thanks for the input. I called Scamp today, even tho I don't think they use Dexter and got the same answer...older-models commonly used the rear-facing axle. Tho the guy had no idea why. I'm going to install "correctly" this time. I watched a video of the Flexiride axle(s) and was impressed. Thanks again for the help.
axle, burro
Replacement brakes for 1983 scamp 13? FJ40Jim Towing, Hitching, Axles and Running Gear 15 09-01-2015 11:09 AM
Floor replacement in a 1983 Beachcomer Michael Murphy Care and Feeding of Molded Fiberglass Trailers 1 08-30-2009 10:01 AM
1983 Burro Axle James Bar. Towing, Hitching, Axles and Running Gear 13 03-15-2009 11:51 PM
SOLD:1983 13ft Burro John Blizzard Classified Archives 2 02-21-2006 08:11 AM
SOLD - 1983 Burro 13ft for sale George Kosta Classified Archives 6 02-14-2006 11:35 AM
