new fridge for 1977 trillium - Fiberglass RV
Old 05-21-2018, 02:33 PM   #1
kg8jk's Avatar
Trailer: '77 Trilliium 1300
I am looking to replace the fridge in our 1977 trillium 1300. I would like it to run on propane and electric. What model fridge is the best fit for the original space?
Our fridge sort of works but not great? Is there some way to improve the performance? I believe it is original.
To be honest, an old fashioned ice box would be just fine as we don't really take extended trips, just a few days at a time.
kg8jk is offline   Reply With Quote
Old 05-21-2018, 03:58 PM   #2
Trailer: Trillium Jubilee
New Jersey
Hi my friend
Look into Dometic
They are excellent
Falicea is offline   Reply With Quote
Old 05-21-2018, 11:06 PM   #3
Microdad's Avatar
Trailer: 1978 Trillium 1300
I put in a ice box in my 1978 trillium works great.not a exact fit had to shim it up with wood.Click image for larger version
Microdad is offline   Reply With Quote
Old 05-22-2018, 05:08 AM   #4
Carl V's Avatar
I'm in the process of replacing a dead RM211 in my sis-in-law's '79 Trillium 1300.
Just got the replacement fridge last night, a used Dometic RM2193 that's very clean and works nicely on all 3 modes.
The only other option was a Norcold 323 (same size as the RM2193). Both these fridges are deeper than the original, so some work is involved in fitting them in. Pushed fully in, the fridge will stick out in front of the cabinet by about 3 inches, this could cause problems in some case (front cabinet door in the way).
Sis-in-law's 1300 is a front dinette model, and the new fridge sticking out 3 inches makes it in line with the front of the bench, so that's just fine.
The RM2193 has the burner on the right and the gas connexion at the same position as the old RM211, so no modification required to the gas line. The Norcold has the burner on the left, and requires a longer gas line to reach the connexion. But the Norcold is apparently less prone to flame outs while driving has the burner is more hidden from the wind (my old popup had a 323 and stayed lit most of the time. The RM2193 is known for not staying lit while driving). Otherwise they are pretty much equivalent.
Old 05-22-2018, 10:11 AM   #5
brendadave's Avatar
Trailer: 1976 Trillium 13 ft
What is the "not works great" part, what does not work great?
brendadave is offline   Reply With Quote
Old 05-22-2018, 10:13 AM   #6
kg8jk's Avatar
It just doesn't get very cold. It does seem to cool but isn't very cold overall. I have the thermostat set to high.
Old 05-23-2018, 12:28 PM   #7
David Tilston's Avatar
To improve the performance of the existing fridge, (RM211?) people have mounted a fan behind the fridge to assist with air circulation. The fan or fans should be mounted between the upper and lower vent and blow upwards.
http://www.fiberglassrv.com/refrig-fan.php
Old 05-23-2018, 01:48 PM   #8
tractors1's Avatar
Trailer: Escape 21 - Felicity
Might try adjusting the thermocouple position and/or replacing it.
Charlie Y
fridge, trillium
Can a 2-way fridge become a 3-way fridge? Rob Carmody Problem Solving | Owners Helping Owners 13 06-24-2016 10:54 AM
VT | 1977 13' Trillium For Sale- NEW NEW PRICE $3500.00 Eyrich S. Classified Archives 4 01-17-2012 05:46 PM
FRIDGE in 1977 13' Scamp? Legacy Posts Problem Solving | Owners Helping Owners 5 12-22-2002 04:56 PM
