1975 Trillium Window Seals - Fiberglass RV
Old 06-07-2018, 08:30 PM   #1
Trailer: 1975 Trillium
Does anyone knows where I can purchase the black seals that go around all the windows of the Trillium Trailers.
Thanks, Carlos
Carlost is offline   Reply With Quote
Old 06-07-2018, 08:53 PM   #2
John in Michigan's Avatar
Trailer: 1979 Boler 1700
Hello Carlos, welcome to the forum! The JR Products 11501 trim is an exact replacement for the black seals that go around all of the Trillium windows. You can buy many places in the US, but I don't know about Canada.
-John
Old 06-07-2018, 09:07 PM   #3
Actually the JR Products 11501 trim that I mentioned above fits perfectly in our Hehr 4900 series windows in our 1978 Trillium 4500. You can check whether you have Hehr 4900 series windows in your Trillium by looking for the model number stamped in the middle of the window sill.
Also many suppliers will send a trim sample for a small charge or no charge.
Old 06-07-2018, 09:33 PM   #4
Window Trim
Hi, John
Thanks for the help.
Carlos
Old 06-08-2018, 01:02 PM   #5
Microdad's Avatar
Trailer: 1978 Trillium 1300
I got mine at woody's Rv.. the come in a package of 5 ....8 feet longClick image for larger version
Microdad is offline   Reply With Quote
Old 06-09-2018, 02:43 PM   #6
Roy in TO's Avatar
Thanks, Carlos
The part the others are pointing to you is the screw cover which is the black strip at the top of the window in your picture.
If you need the seals, there are multiple part numbers.
Old 06-18-2018, 05:07 PM   #7
Trailer: Trillium
Confusion
any other window repair parts?
Do you know of any other window repair parts that are available? I have a window that was broken by the P/O and is missing the aluminum top and bottom rails for the center window.
Sturmey is offline   Reply With Quote
Old 06-18-2018, 08:10 PM   #8
Trailer: 1977 17' Boler
Saskatchewan
Hi Carlost, Give Joe a call at http://trilliumtrailers.com/ Joe is manufacturing all of the new Trillium since 2004 or maybe earlier. The contact number is on the web page Good luck Boler77
Boler77 is offline   Reply With Quote
trillium
Trillium Belly Band and Window Seals garry g Modifications, Alterations and Updates 4 01-25-2016 10:24 AM
Where to buy wheel bearings and seals for a 1975 Trillium 1300 Roadsterrv Towing, Hitching, Axles and Running Gear 5 10-02-2015 11:32 AM
1979 Trillium 4500 Rear Escape Window seals CampingBlairs Care and Feeding of Molded Fiberglass Trailers 0 07-01-2015 09:55 AM
Looking for window seals for Boler door window bomni Problem Solving | Owners Helping Owners 12 04-26-2012 04:51 PM
Replacement window seals and gaskets Mila Care and Feeding of Molded Fiberglass Trailers 1 05-05-2008 09:56 AM
