Rich, You are opening a BIG can of worms.
I have seen owners calk the top of the aluminum belly band, but that is, at best, a band-aid.
The anatomy of the belly band causes a long term problem. First, it is important to understand that the aluminum, and steel plates, (more on that later) are not structural. They are just a tool to line up the top, and bottom shells.
The process to connect the shells goes something like this: The top half and the bottom half are stacked with some 1/4" thick wood bits to keep them from actually touching. The belly band is then riveted, through the gap between the shells, to some 1" x 2" steel plates that are standing up vertically. These plates pull the shells out, and the belly band pushes the shells in. As they work their way around this process lines up the upper and lower shells. When they are lined up,
Trillium ran a fibreglass strip on the inside of the shells to join them. This is the structure.
The biggest problem with this system is that the space that the plates occupy forms a kind of pocket. The upper pocket is no problem, but the lower pocket collects water. This water may come from rain, which the calk is meant to prevent, or it comes from condensation, which no calk can prevent. In the winter, this water freezes, and expands. This rips the pocket slightly larger. Over the course of several winters, the pocket ruptures into the inside of the trailer. Then you have a leak.
The fix is to fill the gap between the shells, and the pockets. Or, at least seal them up so that no more water gets in.
There are many approaches to this.
Mine:
http://www.fiberglassrv.com/forums/f...ead-58763.html
http://www.fiberglassrv.com/forums/f...ead-59580.html
Others:
http://www.fiberglassrv.com/forums/f...and-43322.html
http://www.fiberglassrv.com/forums/f...ion-49308.html
http://www.fiberglassrv.com/forums/f...ium-69274.html
http://www.fiberglassrv.com/forums/f...and-46424.html
http://www.fiberglassrv.com/forums/f...ml#entry338485
http://www.fiberglassrv.com/forums/f...and-44340.html
NOTE:
There is a big difference between the 1300 and the 4500 for this job. On the 4500 there is no fibreglass strip, (bandage) under the back window. The belly band is screwed into a strip of 1/4" plywood. This causes a whole other set of problems. On the 1300 the
fiberglass strip goes all the way around the trailer, so it is less of a problem.
