Bigfoot 5th Wheel Propane tanks - Fiberglass RV
Old 09-28-2016, 09:19 PM   #1
Just purchased a 1984 Bigfoot 5th wheel. Tanks sit on their side. The guy I purchased it from said they are standard tanks. My understanding is that propane tanks should not sit on their sides. Anyone have any wisdom on the tanks? If he has put standard tanks in do I need to replace them?
Timothy B is offline   Reply With Quote
Old 09-29-2016, 10:25 AM   #2
Tom Y's Avatar
Bigfoot 5th wheel propane tanks
In my 86 Bigfoot 5th wheel trailer the propane tanks are in the locker under the overhead part by the hitch. Both tanks are vertical in there, and they are standard tanks. Can take a photo for you if you need it.
Tom Y
Tom Y is offline   Reply With Quote
Old 09-29-2016, 08:31 PM   #3
Trailer: G30 Elite Class C
Tanks
:Tanks sit on side in a lot of larger trailers, CLass B, C, & A Motorhomes I have had all three and the vertical ones and never ever a problem other than running dry and having to find propane dealer. The ones that are removal are the Vertical ones on a Trailer tongue.
Stude
Old 09-30-2016, 10:03 AM   #4
Jon in AZ's Avatar
Like the OP, I was under the impression a different kind of tank is used for a horizontal mount. The best answer will come from your local LP supplier. They can tell you not only whether you have the correct kind of tank but also if they are up to date and safe to use. I doubt they will charge anything just to look at it.
Old 09-30-2016, 10:47 PM   #5
Thanks. I will have someone look at them to make sure they are OK. Google searches seem to indicate they are special tanks, like on a forklift if they are to be laid on their side. The tank's earmarked for the side run in the $200 range rather than the deals you get at Costco. Just thought there might be a Bigfoot owner who might have also ran into this.
Old 10-01-2016, 03:37 AM   #6
Borrego Dave's Avatar
LP tanks are internally designed for use in one mounting stance or another. If your tanks are working as they're mounted you're good to go. On different RV's I've seen with dedicated LP compartments, there is no room to change the mounting position of the tanks. A forklift tank would still be fine, it's still the same LP.
bigfoot, propane
GONE - 2 free propane tanks David & Terry Classified Archives 2 09-04-2008 10:37 PM
Meth Production and Propane Tanks Pete Dumbleton General Chat 8 06-06-2008 09:36 AM
Access to propane tanks Lainey Problem Solving | Owners Helping Owners 5 08-09-2007 03:29 PM
Propane tanks AbenDeb General Chat 15 07-06-2007 12:32 PM
Propane Tanks for a Boler 13' Legacy Posts Problem Solving | Owners Helping Owners 11 07-18-2003 09:13 PM
» Trailer Showcase
Spot
Mr Bill
1974 Boler
nlife
