Bigfoot 17.5 bathroom modification ideas? - Fiberglass RV
Old 10-09-2016, 06:54 PM   #1
Missouri
We have a 2005 Bigfoot 175g with rear bath and don't use the wet bath only the toilet. That seat for the shower is always in the way ! Just wondering if anyone has seen the bath modified to remove the shower or just modify it to remove the seat? I am handicapped with a fused ankle and getting a knee replacement soon I really need the room if possible. I was hoping someone had some ideas or had done anything similar ? Thanks
jcwill is offline   Reply With Quote
Old 10-10-2016, 10:31 AM   #2
re: bathroom mods
I believe it would be tough to remove the seat, drop it to the floor and still have a finished look that would not hurt the re resale value. The RV would most likely have some wiring or water lines that would need rerouting as well. Possibly if you build a sturdy full shower pan step up that may make the access easier with some added height, or as a temporary solution add a portapotty in the trailer till your knee heals up, you also have the advantage of moving it outside to a private area if needed. It is great your still planning to get out and enjoy the outdoors, this should also help with the rehab and getting your mobility back. These washrooms are tight and challenging at the best of times, however don't let me hold you back be sure to post any mods or upgrades.
RB Arthur is offline   Reply With Quote
Old 10-10-2016, 01:14 PM   #3
Missouri
Thank you. I hadn't considered the water lines running under that seat!
Old 10-11-2016, 09:10 PM   #4
If you open the access door on the drivers side at the rear that is your pump etc it is all under that shower seat area. I had a 17g and have a fused right knee can't get that foot in the door when seated, I put my foot in isle and pull the shower curtain. The port a potty is a good idea too.
2008 Bigfoot 27.5FB Anniversary Edition
Tug 2005 Suburban 3/4 ton with 8.1 liter engine.
Martin A is offline   Reply With Quote
bigfoot
Table modification ideas! PrettylilTrilly Problem Solving | Owners Helping Owners 5 03-31-2015 08:44 PM
Hunter Compact-II Ideas, Updates, Bathroom Removal etc. Bob Miller Modifications, Alterations and Updates 3 07-18-2014 10:19 AM
Bathroom or no bathroom, that is the question.. Warren Shumway Care and Feeding of Molded Fiberglass Trailers 71 04-07-2012 04:28 PM
Need Bathroom ideas Gina D. Problem Solving | Owners Helping Owners 21 05-08-2007 11:51 AM
