Thanks for the quick reply
I have the Jelousie style or "surfside" style
windows... i have a 1975
Trillium 1300
I've removed them all and so far I've figured out the plastic covers I need to order to replace the dried and cracked plastic covers over the stainless screws which mount the windows to the camper
I've also seen that it's just Butyl tape that makes the seal and will order the 1/8" x 1" and clean up the excess as it oozes out after the install
The gaskets... or window lock... or window glaze....is what I'm after.
(not sure what these are actually called as they seem to be referred to differently here and there)
I need them for the aluminum window frames around the glass panes which can come right off of the main aluminum frames and are easily taken apart
Can you confirm any part number or measurement I should stick to for a proper tight leak free install?
Thanks again
Ty
