Door Seal 1980 Burro (Will this work?) - Fiberglass RV
Old 12-31-2017, 05:10 PM   #1
Trailer: Burro
Smile Door Seal 1980 Burro (Will this work?)
Hello wonderful Fiberglass trailer owners!
It is almost 2018 and I want to start it off by doing several updates to our Burro we got in October.
I'm looking for a good door seal and have done some research, but wanted to get the OK from the forum before I purchase. Right now there is just some thick weather stripping (halfway hanging off) around the door of the Burro. I am looking to get: Trim-Lok Trim Seal with Side Bulb – PVC Plastic Trim with EPDM Rubber Bulb Seal – Fits 1/4” Edge, 7/16” Bulb Seal Diameter, 25’ Length and place it around the door frame instead of the door.
I've measured the door frame of the Burro and the fiberglass looks to be close to 1/4" thick most of the way around. Let me know if you all think this will work!
I am also going to upgrade our lights with LEDs (7" LED Bus Lights) I'm hoping these will work okay as well. I've never dealt with wiring before but I hope they will not be too hard to replace.
Any feedback is much appreciated!
wxmixte is offline   Reply With Quote
Old 01-01-2018, 03:19 PM   #2
eagle of flight's Avatar
Trailer: burro 1982
door seal
That sounds like it would work. I have a little bit newer Burro. I believe they are the same door. I ordered the Scamp door seal for mine. It works great.
Chiefonelung
eagle of flight is offline   Reply With Quote
Old 01-07-2018, 09:35 PM   #3
Trailer: 1975 Triple E Surfside
I haven't seen a burro to see how much gap there is.. I to just replaced my Boler door seal.. I bought the large bulb one and the door would not close.. TOO thick.. I ended up cutting the bulb off.. then it worked.. The 7 " bus lights work perfectly.. only three wires.. easy and compatible with the typical 4 pin harness. white is ground.. brown is tail light... Red is turn / stop.
Retired and love new projects.. and blog about them
https://www.robeye.ca
robeye is offline   Reply With Quote
Old 01-08-2018, 09:56 AM   #4
Trailer: Burro
Wonderful, thank you for the feed back, I may opt for the Scamp door seal to avoid the issue of it being too thick.
burro
Gap in Burro Door Corner / Door Seal wxmixte Problem Solving | Owners Helping Owners 1 10-31-2017 05:26 PM
Burro door seal YourHighness Problem Solving | Owners Helping Owners 12 08-02-2017 04:52 PM
Burro Trim Lok and door trim/seal nomadicitch Problem Solving | Owners Helping Owners 2 01-19-2014 08:27 PM
burro door seal james e. d. yates Care and Feeding of Molded Fiberglass Trailers 3 03-21-2013 06:47 PM
Burro Door Seal Legacy Posts Problem Solving | Owners Helping Owners 8 02-12-2003 01:39 AM
