98 burro water, black, and gray tank supports - Fiberglass RV
Old 04-11-2018, 10:01 PM   #1
Trailer: 1998 burro 17'
My 17wb burro has chains supporting all 3 tanks and I am afraid of chafing a hole on the edges. I have slipped padding as needed to help but was wondering if 2” seat belt webbing would work. Believe it or not the chains are how it was made, have seen others. I had a fuel tank on a cal 27 sailboat chafe through and was not fun to replace. Or maybe metal strapping with padding. Going to California next month and would like the piece of mind
george w is offline   Reply With Quote
Old 04-12-2018, 12:43 AM   #2
Borrego Dave's Avatar
Do you have slack enough to slide metal ells between the tanks and chain? You see that done on some semi loads to protect the corners of the stacked product.
Old 04-12-2018, 08:06 AM   #3
I have done that but the whole method of chains seems like trouble waiting to happen and the seat belt or tow strap webbing would seem to be much friendlier on the plastic tanks
Old 04-19-2018, 07:59 AM   #4
Joe MacDonald's Avatar
Trailer: 1981 Trillium 5500
I would worry about the webbing rotting out, see a local steel shop and get some 1/8 stainless 1 inch wide and bend it to fit, fasten the ends the same place as the chains
Old 04-19-2018, 10:25 AM   #5
That would probably be a better long term solution, maybe with some rubber padding. I can hardly believe the chain supports haven’t worn a hole yet in 20years
burro
17" Boler Trailer - Waste Water - Black Water Tank waroibns Plumbing | Systems and Fixtures 7 08-02-2020 08:44 AM
Black and Gray water vent pipes kevin61 Plumbing | Systems and Fixtures 4 04-19-2010 06:37 PM
help! clueless about dumping gray and black water tanks joy mccalla Care and Feeding of Molded Fiberglass Trailers 12 04-18-2010 08:13 PM
17' Boler Black and Gray water tank size kevin61 Care and Feeding of Molded Fiberglass Trailers 1 08-30-2009 11:09 PM
Gray/Black water sensors don't work Legacy Posts Problem Solving | Owners Helping Owners 9 08-11-2003 09:28 AM
