1988 Perris Pacer renovation - Page 2 - Fiberglass RV
Old 06-04-2018, 06:36 AM   #21
Trailer: Perris Pacer '87
VA
New cabinet doors made
I had a local cabinet maker make brand new doors for all the cabinets in the camper. $150 for all of them, thought that was a good deal, Can't wait to put them on!
ValleyReb is offline   Reply With Quote
Old 07-09-2018, 07:09 AM   #22
VA
Cabinet Doors are painted!
I went with a color that was a close match with the original interior. Kinda of like a country white / cream color
Old 07-09-2018, 07:42 AM   #23
VA
Vapor Barrier and carpet install
Supplies
  1. -AMERIQUE Laminate Flooring Underlayment Padding with Tape & Vapor Barrier 3-in-1 Heavy Foam 3 mm Thick, 200SQFT per Roll $37
  2. - Marine waterproof carpet 200 sqft from Lowes - $150
  3. -uxcell Car Sound Deadener Application Rolling Wheel Roller 5cm x 3.5cm $9
  4. -3m 90 industrial spray adhesive $13/can 8 cans
I went with the underlayment padding because it is closed foam, provides the camper with a strong moisture/vapor barrier, mold and moisture protection, non allergenic, sound absorption, the bright blue look gives me some additional opacity to prevent light from penetrating, it has anti-crush technology for excellent performance and long life. It is perfect for fiberglass adhesion, 3mm closed foam technology for sound reduction, and a tiny bit of insulation. I don't see winter camping very often so it wasn't a concern for me.
TIP: I found that you must apply a coat of adhesive on both the wall and the foam and then the foam and the carpet for the adhesion to be strong enough.
Old 07-09-2018, 07:47 AM   #24
VA
pictures:
Old 07-10-2018, 06:58 AM   #25
ShelbyM's Avatar
Trailer: Casita SD
Very nice!
ShelbyM is offline   Reply With Quote
Old 07-12-2018, 12:44 PM   #26
VA
Taking the 30yr old window moulding out
So I went to the scamp website and ordered two set of mouldings with the lockstrip $40 each and then onto Amazon for the lockstrip tool (gotta have) then I used armorAll to lube the lock strip so that it would feed quickly. Watch the corners. Had a tough time getting the glass to settle into those, it kept popping out. Used a screw driver and the locking tool to set the main moulding and armorAll to lube the glass as well.
Old 07-16-2018, 11:29 AM   #27
VA
Closet finished, Cabinet Doors Hung!
Almost done! I have the last of the carpet to do, finishing up the interior of the cabinets with the same carpet as the walls. All I will have left is the flooring which we are doing a soft feel linoleum with a wood texture.
55329985244__F424632C-DC36-442E-BD8E-0DCBDB9FEC8F.jpg   55329999396__D5A07607-3D80-4583-BC42-7EC1838C6A44.jpg
55329988868__08257AF6-03F2-4277-9145-3D7DAB62E726.jpg   55329986772__D4430D8F-3394-409C-BD23-CF41AD6D37B8.jpg
Old 08-06-2018, 09:05 AM   #28
VA
cabinet locks and color scheme
Went to the Trailer Supply Superstore and ordered brushed brass cabinet locks and starting to go with the color scheme of kind of mixed and matched Bohemian style...more to come
Old 08-06-2018, 09:12 AM   #29
WaltP's Avatar
Trailer: 2017 Escape 17B
SW Virginia
Looking very nice. Thanks for all the pics.
Walt
Old 08-12-2018, 05:46 PM   #30
Chico, California
The interior looks so good! I'm running into a couple road blocks and have a couple questions.
1. Did you remove the fiberglass seat bases or cabinatry frame in kitchenette to get the carpet behind it on the walls? My current carpeting goes behind these things but they are riveted in from the outside and that's opening a whole can of worms.
2. How did you remove the table? I can't seem to remove mine from the metal base on the floor.
Thank you!
April Kelly is offline   Reply With Quote
Old 09-04-2018, 09:51 AM   #31
VA
Linoleum is installed
Bought a remnant from Lowes, used PVC moulding and loctite instant glue to put the moulding in place. Shes almost ready to go!!
Old 09-04-2018, 10:02 AM   #32
WaltP's Avatar
SW Virginia
Impressive. I'd love to see it. Where in VA are you?
It'd be nice to have you join our fiberglass mini rally at Hungry Mother SP in early November. You'd be our first vintage trailer.
Walt
Old 09-04-2018, 02:46 PM   #33
VA
Walt
That would be fun! send me some info! I am near Winchester Va
Old 09-04-2018, 04:23 PM   #34
WaltP's Avatar
SW Virginia
I call this a mini rally because it is small and has no agenda.
This will be the 6th year and we typically have 12-14 fiberglass trailers of various brands and vintages.
It will run from Friday through Sunday with some arriving late Thursday. Dates are Nov. 1-4
I say no agenda, but Friday night I make Cowboy Stew and SUMI salad and others are welcome to supplement or not. I always worry there'll be enough to go around, but so far so good.
We camp in the Burson Campground at Hungry Mother, which is one of the few State Park campgrounds open year round. Sites have electric and water hookups and some also have sewer. There is a dump station and a nice, modern bathhouse with showers.
It's a nice area with lots to do, including hiking, paddling, some nice local museums and more. Some nice restaurants in nearby Marion Too.
I hope you can make it. Some nice restaurants in nearby Marion too.
And some have talked about doing the easy bike ride down the mountain at Damascus.
Walt
Old 09-04-2018, 07:42 PM   #35
blueruby's Avatar
Trailer: Mini T
Smile Flooring
Hey there, I LIKE your floor. Might run with that.
Bruce
blueruby is offline   Reply With Quote
Old 09-06-2018, 09:23 AM   #36
VA
Thanks for the info, I am putting it on my calendar!
Old 09-06-2018, 09:37 AM   #37
VA
Walt
So are there specific campsites that y'all use?
Old 09-06-2018, 10:03 AM   #38
WaltP's Avatar
SW Virginia
Not really, but we do seem to cluster in sites furthest from the park entrance and closer to the bath house.
Burson is pretty compact and all 51 sites are in view of each other.
I hope that helps.
Walt
perris pacer
BEAN's (1988 Perris Pacer) Reno--Pics!! Vickie B. Modifications, Alterations and Updates 28 02-16-2021 03:45 PM
1974 Perris Pacer Renovation Fredomatic Care and Feeding of Molded Fiberglass Trailers 52 07-13-2020 06:17 PM
1982 Perris Pacer Renovation Robert Johans Modifications, Alterations and Updates 55 03-21-2015 12:14 AM
1988 13' Perris Pacer Vickie B. Classified Archives 6 08-26-2009 03:22 PM
