74’ Perris Pacer Reno - Dining Table - Fiberglass RV
Old 11-20-2019, 03:32 PM   #1
Fredomatic's Avatar
Trailer: 1974 Perris Valley Pacer
Hi Everyone
I’m installing the dining table after replacing the floor. I can’t remember if the screws/bolts holding the table base to the floor just screw to the floor board or pass all the way through to secure with but from underneath. I guess I could start by just screwing it and if the fasteners pull out I could bolt through. Any insight from Pacer owners or other trailers that use the table leg base Click image for larger version
ID:	132331would be much appreciated.
Frederick
Fredomatic is offline   Reply With Quote
Old 11-20-2019, 11:22 PM   #2
Trailer: perris pacer
Originally Posted by Fredomatic View Post
Hi Everyone
I’m installing the dining table after replacing the floor. I can’t remember if the screws/bolts holding the table base to the floor just screw to the floor board or pass all the way through to secure with but from underneath. I guess I could start by just screwing it and if the fasteners pull out I could bolt through. Any insight from Pacer owners or other trailers that use the table leg base Attachment 132331would be much appreciated.
Frederick
Hey Fred
If I look under ours where the table would be there is a circular rivet pattern right there. But I would imagine if you put down a substantial floor (plywood) you could go right to that.
Where did you get your table vase by the way? We are in the middle of renovating a 1974.
Oldskater68 is offline   Reply With Quote
Old 11-21-2019, 11:21 AM   #3
francene's Avatar
Trailer: 13 ft Compact II
SS Screws
I just used some hefty, stainless steel screws into the vinyl sheeting-covered plywood subfloor, and it's still firm years later.
Forgot to say I got my table base on Amazon or Ebay. (Can't recall;it's been a while!)
Fran
Compact II 1974
francene is offline   Reply With Quote
Old 11-21-2019, 11:23 AM   #4
Fredomatic's Avatar
Originally Posted by Oldskater68 View Post
Hey Fred
Oldskater
If you have rivets, I think they most likely went through to the underside. The Pacer has a plywood floor plus I added composite cork on top. I’m going to try using screws first then change it if it’s weak.
I’m reusing one of the original bases, made locally in Santa Ana. The other cracked. I purchased a similar set online. I have a couple of extras if you want them. PM me your info.
Is your 74’ a Pacer?
F
Old 11-21-2019, 11:25 AM   #5
Fredomatic's Avatar
Fran
Compact II 1974
Thanks Fran! That’s what I’ll do. Cheers
Old 11-21-2019, 12:08 PM   #6
Oldskater
F
Fred
Thank you for the offer of the table base. We are a long way away from that .
It is a Pacer. And there is something unique about it I have noticed. It has a “minit” symbol on it by the door.
perris pacer
BEAN's (1988 Perris Pacer) Reno--Pics!! Vickie B. Modifications, Alterations and Updates 28 02-16-2021 03:45 PM
Metal pole removal from scamp RV dining table robertmarchiony Problem Solving | Owners Helping Owners 14 04-11-2015 08:26 AM
Looking for a bigger dining table billkateposs Modifications, Alterations and Updates 18 10-08-2013 07:51 PM
Trillium 1300 - Information on shelf over dining table Booker B. Problem Solving | Owners Helping Owners 12 04-20-2008 09:54 PM
Wanted: Trillium Dining Table hardware Booker B. Classified Archives 4 03-25-2008 02:36 PM
