boler door window - Fiberglass RV
Old 04-30-2014, 06:11 AM   #1
rosey45385's Avatar
Trailer: 1972 American boler
boler door window
when I purchased my 72 boler the door needed the correct hinges to be installed on the door. took it to a friend who has a body shop. A p.o.had installed a solid window and did a bad job the door was cracked and the window was broke it was a real odd slze I coild not find any information on that size of window .So my friend repaired the door and filled in the area of the window. I have a 6 x 18 inch window that came out of another boler. I would like to know the length of screw and if they go into wood strip on the inside? what size wood strips. have not seen a good picture of this window on the inside of a boler door.
rosey45385 is offline   Reply With Quote
Old 04-30-2014, 06:32 AM   #2
Alf S.'s Avatar
Send a message via Yahoo to Alf S.
Hi: rosey45385... The door window on most bolers was a Hehr window and pop riveted to the fiberglass . It was also used on a lot of Airstreams. Our boler had one as the kitchen vent. I rebuilt it and replaced the rivets with S/S screws and wood strips as clamps inside. All gaskets were avail. from Vintage Trailer Supply.
Alf S. North shore of Lake Erie:
Alf S. is offline   Reply With Quote
Old 04-30-2014, 07:54 AM   #3
Ian G.'s Avatar
As Alf said these windows came pop-riveted from the factory through the window frame into the fiberglass shell. I would recommend you use either aluminum rivets or if you use a wooden frame inside you should use aluminum screws (available at most hardware stores).
Dissimilar metals against each other will result in galvanic corrosion, using similar metals will prevent or reduce this problem.
Old 05-06-2014, 03:08 PM   #4
Trailer: 1972 Boler American
Missouri
Rosey,
The source for the seal that sets against the window (when it closes) only comes in a long length. Way more than is needed for one window. If you are going to or have purchased the seal from VTS I would like to share some of the cost with you for a length of it for my window.
JasonK is offline   Reply With Quote
boler
Looking for window seals for Boler door window bomni Problem Solving | Owners Helping Owners 12 04-26-2012 04:51 PM
Window Gasket, Window Seal, Window Molding D Shubel Problem Solving | Owners Helping Owners 9 05-16-2011 04:30 PM
Old side window & door window needed sherry loving o Classified Archives 0 06-12-2008 03:15 PM
