burro gravity furnace installation? - Fiberglass RV
Old 03-05-2017, 08:20 AM   #1
Trailer: Burro, had aliner
Has anyone had any experience installing a gravity furnace (no fan, no electric required) into a Burro? I have a 1978, 13 ft, in pretty rough shape. I am not adverse to the idea of cutting hole into the exterior wall to install the vent for a furnace.
As far as I can tell, Burros did not come from the factory with any type of furnace. If someone knows different, please correct me as this might make my efforts much easier. What kind of furnace do you have in your burro? Where did you mount it, and how did you vent it?
I use this during the winter, need it vented to the outside because of moisture (and of course CO) build up on the inside as is happening now with my "Buddy" heater
fred wark is offline   Reply With Quote
Old 03-05-2017, 12:18 PM   #2
I cant understand why they went away. They work extremely well. Just make sure you have the required space around the unit so it will not catch anything on fire.
Old 05-06-2017, 11:00 AM   #3
Trailer: Burro
I just got my 1972 burro 13' and it has a factory heater..its located by the door under the closet. If you are standing outside the door, it'll be on the left, directly across from the a/c unit. I think its electric. My burro is wired for ac and dc with a flip of a switch.
erickang411 is offline   Reply With Quote
Old 06-11-2017, 08:07 AM   #4
Trailer: Parkliner
I have a 1981 Burro that I just started a restoration. When we purchased the Burro the PO had the heater sitting on a shelf and it looked terrible but i wanted to try and save it since it was original to the trailer. I had almost hiven up hope but then found this website,
http://ventedcatheater.com/6.html
The Cat heaters came orginonal to alot of the Burros. I spoke to Arnie at Cat heaters and he is now in the process of rebuilding my heater for me. He also builds new trailer heaters upon request.
Annie Snyder
2011 15' ParkLiner
AnnieSnyder is offline   Reply With Quote
Old 04-21-2018, 09:08 PM   #5
Mike Magee's Avatar
Trailer: 93 Burro 17 ft
Just adding to this older thread...
Today I came across a possible alternative to a gravity furnace. It's called a Nu-Way 2000 propane stove. No fan or electricity, and no thermostat per se, but the (12,000 btu max) burner is adjustable from high to low. In an egg, low should be just about right on a cold night. Model 2000 - Nu-Way Stove
The Nu-Way is made in Onaway, MI and they have been used for decades in ice fishing shanties. The flue adjustment helps retain most of the heat in the lower pipe.
Name:	Nu-Way heater-stove.jpg
Of course, it will take up floor space (9.5"x7" footprint, 15" high) and the 3" vent pipe will take up space as well. But this might work for someone, so I thought I'd mention it. Even with the pipe and all hardware, the whole thing should only cost about $200 or so.... much less than a Dickinson!
Old 04-21-2018, 11:15 PM   #6
Glenn Baglo's Avatar
It will take up floor space, plus the clearances required to walls and ceiling.
Old 04-22-2018, 07:44 AM   #7
Missouri
i have seen
fred I have seen pictures here with a remodel they mounted a wave 3 heater on a cabinent door.
might be a possibility for you
bob
burro, furnace
Duo-Therm Gravity furnace manuals Raya Care and Feeding of Molded Fiberglass Trailers 30 02-09-2021 09:14 PM
Duo-Therm gravity furnace not working properly Rick G Problem Solving | Owners Helping Owners 9 12-08-2015 05:46 PM
exhaust grate for gravity furnace on 1972 Boler Cheryl Lee Care and Feeding of Molded Fiberglass Trailers 1 06-25-2009 02:57 PM
REMOVING a DuoTherm gravity furnace Marv Watson Problem Solving | Owners Helping Owners 5 06-08-2009 05:57 PM
Duo-Therm Gravity Furnace Jake Jacobson Classified Archives 1 11-10-2008 04:13 PM
» Trailer Showcase
THE boler
Luis
Beastie
BobB
