Door hinge pin of 79 Surfside - Fiberglass RV
Old 03-14-2015, 06:30 PM   #1
surfside up's Avatar
The problem I have is the pin of the door hinge has, through the years, moved up, out of the lower hinge socket, and no longer engaged in the lower part of the hinge. The door won't hang correctly because of it. The photos below show the pin sticking up approx 3/8" above where it should be. The other pic shows how it should be. I've tried to reposition the pin by hammering it with nail set and drift pin, but it won't budge.
Are there any machinists out there that could shed some light on this problem?Click image for larger version
Name:	ImageUploadedByFiberglass RV1426379358.274695.jpg
ID:	81329Click image for larger version
Name:	ImageUploadedByFiberglass RV1426379398.359946.jpg
surfside up is offline   Reply With Quote
Old 03-14-2015, 07:48 PM   #2
Maybe the pin is not aligned with the bottom hole in the stationary part, therefore you can't drive the pin back where it should be. Most likely this is the issue as you say the door doesn't hang correctly.
Old 03-14-2015, 11:40 PM   #3
The pin definitely has to be precisely aligned in the hole. I have also tried to tap the pin up, to remove it entirely, but was unable to move it.
My thought is that possibly the hinge was heated to expand, before the pin was driven in. The cooling process then seats the pin solidly. I have no idea why or how the pin could have loosened up to where it is now though.
Old 03-15-2015, 07:06 AM   #4
Probably a "press fit", where the tolerances are very close between the pin and the hole requiring it to be pressed together. I would hesitate to hammer on it much as you risk breaking something. You'll probably have to remove the hinge, then find a way to press the pin back in, like in a vise. Heat on the hinge may help.
Old 03-15-2015, 02:39 PM   #5
I think it's time to call in a favour to my millwright brother-in-law!!
Old 03-15-2015, 03:10 PM   #6
When I was a maintenance machinist at GE we called the millwrights the "Bulls" as they did all the heavy work LOL. Ask your brother in law if he's ever seen a "Bull of the Woods" calendar. Sort of like "Dilbert" but for the machinist trade. I haven't seen one in many years.
Old 01-12-2016, 06:24 AM   #7
New Hinges Lee Valley Part number 01H01.50 $ 26.00 something for 2 much stronger look Lee Valley up on line love the catalog .we have a store in west Edmonton.
surfside
Scamp Hinge pin assemblys Perry J Care and Feeding of Molded Fiberglass Trailers 14 04-19-2013 09:29 PM
Boler door hinge repair kit and fridge access door John Jesse Problem Solving | Owners Helping Owners 5 05-27-2011 12:32 PM
Changing from 6 pin to 7 pin on truck - how?? Shelley Towing, Hitching, Axles and Running Gear 4 07-28-2009 10:45 PM
boler door hinge pins Ben, Vanden Berg Problem Solving | Owners Helping Owners 9 07-23-2009 12:25 PM
Flat Pin vs Round Pin Connectors Legacy Posts Problem Solving | Owners Helping Owners 7 04-07-2003 11:34 AM
