Bigfoot cabinet removal - Fiberglass RV
Old 04-20-2015, 11:36 AM   #1
Can anyone performing/has performed a restoration on a Bigfoot trailer give some insight concerning removing the overhead and floor cabinets? I have a wall area in need of repair due to water damage and am having difficulties determining how the cabinets can be removed (screwed/riveted into the wall paneling, ceiling, etc.). I have a 2001 BF 17' trailer. Thanks in advance!
squatch-lover is offline   Reply With Quote
Old 04-22-2015, 07:43 AM   #2
Trailer: bigfoot
I did a reno on my 89 Bigfoot, the cabinets were all just screwed in, there is plywood embedded into the ceiling and the walls at certain points, depending on the floor plan. If you're going to remove the upper cabinets I would probably support the ceiling somehow while you do the repairs, especially if you have a A/C on the roof. You don't want the insulation to crack because you will certainly lose the integrity of the ceiling
Hope this helps
ken jon is offline   Reply With Quote
Old 04-22-2015, 09:24 AM   #3
It does help, Ken! Thank you!
Old 04-22-2015, 10:57 AM   #4
Hey I will give you my 2 cents here. I have been restoring my '81 B17. Front cabinets are a breeze. Start at the small one closest to the door and work your way around to the kitchen. It has to be taken down in order as they are screwed to each other. I didn't seem to need support but I have not gotten past the middle yet. There are small strips of wood in the ceiling for mounting as well as in the walls. I noticed that the first small cabinet beside to door had nothing in the walls to screw into, so when it goes back together I will put a strip in to support the cabinet. Hope this helps!
Bigfeet is offline   Reply With Quote
Old 04-22-2015, 05:06 PM   #5
Thanks, Feet! Was just looking at your reno....nice!
Sent from my GT-P5210 using Fiberglass RV mobile app
bigfoot
Bigfoot Furnace Removal mitch Problem Solving | Owners Helping Owners 7 08-04-2014 02:27 PM
71 Boler 13' Floor Removal/ Shell removal mikeandmadi Problem Solving | Owners Helping Owners 1 05-23-2011 10:28 AM
Seating/Cabinet Removal shelley w Problem Solving | Owners Helping Owners 4 08-06-2009 12:40 AM
