2" receiver on Escape 17B rear bumper - Fiberglass RV
Old 06-28-2016, 09:10 PM   #1
Trailer: Escape 17B
Nevada
I just finished installing a 2" receiver on my 17B.
Took 2 12"x12"x.125" steel plates from an old project, and glued them together with PL Premium.
Drilled a few holes, bolted on a step bumper receiver hitch, and attached the whole shebang with u-bolts to the bumper.
seems burly enough for a couple of bikes or a bin full of stinky slinkies.
Will take it for a test drive with bikes attached and wife following to see how much movement goes on when cruising down the highway.
Jim99 is offline   Reply With Quote
Old 06-29-2016, 04:50 AM   #2
The Minimalist's Avatar
Trailer: 08 Weiscraft Little Joe 14 Subaru Outback 2.5i CVT
Louisiana
Jim:
I don't know how many bikes you are putting back there, but it is wise to check your weight distribution before any lengthy trip. You should have 10 to 15% of the trailer weight on the tongue for safe towing.
Clif
The Minimalist is offline   Reply With Quote
Old 06-29-2016, 04:51 AM   #3
Keaner's Avatar
Trailer: 1973 13' Boler
what grade bolts did you use?
Keaner is offline   Reply With Quote
Old 06-29-2016, 07:52 AM   #4
Trailer: Escape 17B
Nevada
grade 8.8
Old 11-10-2016, 06:43 PM   #5
Trailer: Escape
Montana
nicely done
That's a nice solution. I have been toying with an alternate approach, and don't have it finished quite yet - a Curt bumper hitch mount designed for a 2"x4" bumper, than fill in the difference from the 1.5"x3" bumper on the Escape with a couple of hardwood shims.
philostechedon is offline   Reply With Quote
Old 11-10-2016, 07:42 PM   #6
Trailer: Escape 17B
Nevada
I also looked at the 'rv bumper' receivers... I wanted to stay away from twisting forces on the bumper tubing as much as possible.
I am thinking of 'upgrading' my receiver setup to have a thicker steel plate; with two light-ish bikes (about 55lbs combined) and 15lb bike rack there's really too much flex (meaning I notice it with my eyes).
Also, the harbor freight receiver is pretty big, so anything I put in the receiver wiggles around a lot.
Both of these cause more movement than I'd like, and I think I can solve all the problems for $50 or so. Most of the money used for a nice drill bit
Old 11-10-2016, 08:10 PM   #7
Originally Posted by Jim99 View Post
grade 8.8
8.8 is a marking used on metric bolts that are a mild carbon steel, about the same as a US grade 5. Keep in mind that bikes on a rack, combined with any trailer bounce on a rough road will use the leverage effect on your receiver. I've built a few by installing two cross members to the frame rails and attaching the receiver tube to both. Look at the rear receiver that Orbital Machine sells for Casitas, very nicely done. I made mine similar to that.
escape
Putting a receiver hitch on the rear bumper of a SCAMP 16 johnanv Towing, Hitching, Axles and Running Gear 23 03-15-2015 08:09 PM
Scamp Rear Receiver Hitch Larry Singer Towing, Hitching, Axles and Running Gear 18 07-15-2010 03:17 PM
Need bracket for 4" rear bumper Michael Pupeza Modifications, Alterations and Updates 4 05-29-2009 07:53 AM
"U-Hitch" Rear Hitch Receiver Tim Ryce Modifications, Alterations and Updates 9 03-12-2009 04:05 PM
castors for rear bumper Legacy Posts Modifications, Alterations and Updates 5 01-17-2003 03:00 AM
