Hey guys,
This is my first post on the forum! I bought a
Trillium 1974 recently. In the last few days it has being raining alot and I discovered some leakage on the back seat (driver side) at the jonction of the insulation and the
fiberglass.
At this point, I'm not sure if the water is coming from the driver back side window since all the interior wood frame is covered with the former insulation. I read on some threads that adding caulking outside on the jalousie window is not necessary but since I would prefer to use the trailer instead of unmounting the
windows, I tried to add some mono ultra outside and see the result (back seat driver window only). There is still some leakage happening.
The water appears on the junction of the insulation and the
fiberglass on the seat. Waters comes from the rear of the insulation which makes it hard to see the starting point:
And then leaking in the box:
Windows from outside:
Caulking:
Any hint on what to do next? Could the water be coming from the middle junction of the trailer. There is caulking on top:
But not on the underside:
Any help will be greatly appreciated. If it comes to removing the
windows and redo the butyl tape, ill do it but before that, I wanna make sure I'm not missing something. Thanks alot!
