Forgive me Scamp faithfull, I looked at a Lil' Snoozy and liked it - Fiberglass RV
Old 05-31-2014, 09:00 AM   #1
Timber Wolf's Avatar
North Florida
Saw one just as we were pulling into the campground last week. The couple appeared to be packing up so I rolled down my window and asked to look at their rig. They were glad to show it to us. While not perfect (I would like the wheels flush with the side of the body), I really, really liked the layout. I am not ready to trade off my Scamp 16 yet but maybe someday.
Old 05-31-2014, 11:19 AM   #2
SusieinNC's Avatar
Trailer: 2012 Lil Snoozy #151 - sold in 2018
Snoozy
Tim, the fact that the tires are out a bit gives the Snoozy a very stable feel.
SusieinNC
SusieinNC is offline   Reply With Quote
Old 05-31-2014, 11:28 AM   #3
David B.'s Avatar
And you don't need extended mirrors on the tow vehicle....we just picked ours up and brought it home Thursday.
Old 05-31-2014, 12:43 PM   #4
North Florida
I understand the stability, but my Scamp is much higher, and the track narrower and I have no stability problems. To be brutally honest, I see no reason other than cost or engineering that Snoozy does not inset the wheels. I like the layout, but would not buy something that hangs that wide.
Old 05-31-2014, 01:19 PM   #5
Trailer: Escape 21 Nov.2016
wheels
Why I liked the wheels outside is if you get a flat it doesn't bust up the fiberglass body like some of the others plus it is more stable and you don't need oversize mirrors .
jennykatz is offline   Reply With Quote
Old 05-31-2014, 02:40 PM   #6
Kudzu Asheville's Avatar
Trailer: Alto R1723
Would you please explain why the wheel placement prevents extended mirrors from being needed? I'm a newbie and assumed extended mirrors were to see approaching traffic.
Sent from my SM-G900V using Fiberglass RV mobile app
Kudzu Asheville is offline   Reply With Quote
Old 05-31-2014, 05:14 PM   #7
lil snoozy
The camper is 8ft wide including wheels the box itself is 78in so we dont need extra stick out mirrors like some of the other campers. Go to lil snoozy .com he explains it
Old 05-31-2014, 06:10 PM   #8
Roy in TO's Avatar
You actually use the mirrors to see what's behind you. Approaching usually means what is in front.
If the body of the trailer is narrow enough when compared to the tow vehicle, you don't need extended mirrors.
Old 06-13-2014, 05:33 PM   #9
Roger C H's Avatar
Extended mirrors
You may not need mirror extensions but you then have a narrower trailer. Lil Joe has the same feature.
Old 06-13-2014, 06:24 PM   #10
Bob Miller's Avatar
Trailer: Class A Motorhome
Geeee....
Aren't most FGRV's like SCAMPS, Bolers, and all of the eggs about 78" wide? Ya almost have to be that wide to fit in east-west beds. Which is to say that the Lil Snoozy really is a lot wider without the benefit of additional inside space. You still have to keep those "Wide Track" wheels on the road and into camping spaces.
FWIW: Credit for inventing "Wide Track" goes to Ford, not Pontiac.... There was a version of the Model "T" Ford available with a wider front axle and spacers on the rear axle so that the wheels could ride in the wagon runts in rural areas.
Old 06-14-2014, 06:30 AM   #11
Trailer: currently shopping
Missouri
I'm doing my research into buying a FG camper. As a tall person, 6'5", the Egg Camper and Lil' Snoozy are the only ones I have found that accommodate my height. Hope to visit the Egg factory this summer.
Missouri Mark is offline   Reply With Quote
Old 06-14-2014, 07:31 AM   #12
Bob Miller's Avatar
Yep, you can bet that FGRV's aren't popular with basketball players.
Old 06-14-2014, 07:46 AM   #13
If one looks at utility trailers or uhaul rentals the wheels are always out (wide track ) This give a lot better stability and if you get a flat a lot easier to fix and work on trailer brakes, bearings etc . If your in a parkliner , boler, scamp,or casita what happens if you have a blowout at 6o mph and tire blows right through fiberglass wall ? I like to hear from these owners that have had blowout at highway speed and if it wrecks the fiberglass shell? that was my thought when we bought our Lil snoozy
Old 06-14-2014, 08:31 AM   #14
Bob Miller's Avatar
Gotta say, most of the dozens of tire blow-outs, both on FGRV's and mini motorhomes that I am familiar with occurred with over age tires. Yes, a few have happened with newer tires, some that had prior road damage but, after you remove the number of blowouts from those causes, the number of blowouts on RV's is very small and, IMHO, not sufficient enough to warrant making a selection based on the fear of that happening.
BUT... in one FGRV I saw several years back, the owner had squeezed metal trailer fenders into the existing wheel wells as armor to protect against blow-out damage.
Bottom line: Take care of your tires, do not leave them exposed to sun during storage, monitor tire pressure, inspect for damage often and toss them on their 5th birthday. And, BTW, don't buy cheap tires.....
I have seen it mentioned in earlier posts that the Lil Snoozy frames are built by a boat trailer builder, which might better explain the wider stance.
Old 06-14-2014, 10:35 AM   #15
Carol H's Avatar
Easier? How does that work? In order to fix a flat, brakes or bearings all wheels need to be taken off the trailer and the process for doing that is no different on the trailers listed vs the extended out wheel as found on the lil' snooze. What am I missing?
I have had tire failures and not had the tire blow through the fiberglass. Although I am aware that can happen I don't believe it is as common an event as some may believe.
Old 06-14-2014, 09:39 PM   #16
Roger C H's Avatar
Cool Sizes
Hmm. From the Lil Snoozy website, the inside width of the trailer is 6' 6" (or 78"). The bed is 63x79". How they get a 79" bed into a 78" space must be interesting to see.
David, what IS the side to side dimension of your bed? (I assume the 63" dimension is front to back.)
My Trillium bed measures 77x45" (or 6' 5" x 3' 9"). The brochure states overall (outside) width as 6' 7" or 79".
So, the two are about the same width, so the idea of accessory mirrors or not seems moot.
Another point, is the Snoozy is 8' (96") over the tires. In Washington, being over 80" requires running lights, that is corner lights, and three lights in the center showing red to rear and amber to the front as well as lights at the widest points.
Old 06-15-2014, 07:01 AM   #17
North Florida
I started this thread because I was impressed with the layout of the Snoozy, but since then have noticed there are several (older) rear entry trailers out there with similar layouts. They are not necessarily eggs (Grasshopper, Taylor Coach) but have the layout that more closely fits the way we camp and use a trailer. It looks like Snoozy made a decision to use “stock” type components (axle, frame, fenders) and a smooth sided shell without wheel wells as both cost cutting measures and fabrication streamlining elements. These are not bad things when construction efficiency crosses path with lower price and better or at least not reduced suitability for use.
That is the rub, the Snoozy is not (IMHO) “cheaper” (from MSRP prices I have seen) and the “wide track” does not fit the way I drive or camp. I tend to hug the side of the road when towing, always have and just prefer to do so especially with oncoming traffic on the (narrow) roads I frequent. I want to be able to run my TV over to the edge without the trailer running off the road or taking out mailboxes. In sum, I see negatives to the outside wheels without sufficient advantages to counter it.
I have actually had a tire come apart and do significant damage to a vehicle. It was a Chevy Blazer and a Firestone tire that literally tore off the end joint and hanger of the exhaust pipe. That was a rare occurrence and I did not go looking for vehicles with outside wheel wells because of it and will not be basing a trailer buying decision on it either.
lil snoozy, scamp
Lil Snoozy adopted and brought home to NC Melanie B in NC Problem Solving | Owners Helping Owners 19 11-07-2013 06:35 PM
Good Thing Someone Looked Cyndi B. General Chat 5 07-27-2013 09:01 AM
Lil Snoozy vs Scamp discussion (split from Classifieds) melissab General Chat 98 01-20-2013 12:03 PM
Looked at a Casita today.... Cricket General Chat 4 09-18-2012 06:54 AM
Looked at my first 13 Scamp today Duane Fowler General Chat 21 04-10-2007 05:40 PM
» Trailer Showcase
Rucio
jen b
Scrappy
hecdawg
