Lil Snoozy door lock fix - Fiberglass RV
Old 01-04-2015, 04:57 PM   #1
MCDenny's Avatar
Trailer: Lil Snoozy
My trailer, #136 I believe, has had the door lock fail twice. A year ago we were locked out and had a locksmith at the trailer and the Snoozy factory on the phone trying to find a way in. Once we got in it turned out that the screws inside the lock mechanism had vibrated loose disconnecting the dead bolt from the key. I figured the screws were never tightened properly so put it back together and it has worked fine until now.
This time it failed in the unlock position so no problem getting to the lock mechanism. This time I used blue lock-tite so hopefully this time the repair will last.
In case others have a similar lock mechanism, maybe a little preventative maintenance would be worthwhile.
Take these four screws out and move the face plate.
Name:	ImageUploadedByFiberglass RV1420412142.617523.jpg
These are the screws that come loose. Remove them, ONE AT A TIME, and reinstall with a drop of lock-tite on the threads.
Name:	ImageUploadedByFiberglass RV1420412268.091519.jpg
Denny Wolfe
Wanderingourway.wordpress.com
MCDenny is offline   Reply With Quote
Old 01-04-2015, 05:18 PM   #2
charlsara's Avatar
Trailer: 2014 Lil Snoozy
Thanks Denny. I will check ours out. It got tight one time and I sprayed the lock with WD-40. That seemed to fix it.
charlsara is offline   Reply With Quote
Old 01-04-2015, 07:12 PM   #3
David B.'s Avatar
On the Lil Snoozy website, they have a recall site.....checked to see if ours was on the recall, and it wasn't, but I believe I will put some lock-tite on the threads as you have. Thanks for the reminder.
Dave & Paula
Old 01-04-2015, 08:13 PM   #4
Trailer: Escape 21 Nov.2016
recall
Check out snoozy for recall just call them they send new door lock free Good Luck Are you coming down to sw florida anytime soon Jim
jennykatz is offline   Reply With Quote
Old 01-04-2015, 09:34 PM   #5
MCDenny's Avatar
Trailer: Lil Snoozy
Jim, were in Port Charlotte right now. Camping at Koreshan Monday and Tuesday, Collier Seminole Wednesday to Friday.
Denny Wolfe
Old 01-04-2015, 09:51 PM   #6
MCDenny's Avatar
Trailer: Lil Snoozy
Dave & Paula
My code was not on the recall list either. My deadbolt failed twice though, both times those little screws vibrated loose.
Denny Wolfe
Old 01-15-2015, 03:53 PM   #7
Fly fishing david's Avatar
Trailer: lil snoozy
Ohio
Thanks for motivating me to finally fix my lock
Fly fishing david is offline   Reply With Quote
Old 02-26-2015, 08:14 PM   #8
charlsara's Avatar
Got mine done. The screws were not loose but they weren't tight either.
lil snoozy
door lock didn't work -turns out to be an easy fix Daryl and Wendy Problem Solving | Owners Helping Owners 4 08-08-2013 10:57 PM
Lil Snoozy vs Scamp discussion (split from Classifieds) melissab General Chat 98 01-20-2013 12:03 PM
New Camper - Lil Snoozy Old Man Snoozy General Chat 7 08-08-2011 06:12 PM
Query about door lock to lock from inside sara maccalman Problem Solving | Owners Helping Owners 4 11-14-2010 07:11 AM
