Oxygen shore power cord modification - Fiberglass RV
Old 01-08-2015, 10:12 AM   #1
Trailer: Bonair
Nova Scotia
I’m not sure if this a common problem but after pulling the power converter to do some wiring mods I noticed my power cord appeared to be running the risk of entanglement with the wiring harness and possibly causing damage. The space is limited and in cold weather makes the situation worse as the cord loses most of its flex. Thought about replacing the cord with something lighter or shorter but ended up installing an outside inlet and carrying the power cord in my van. Hopefully makes the setup easier as well as eliminating a wiring problem which for me would take days find.
Vann in NS is offline   Reply With Quote
Old 01-08-2015, 11:43 AM   #2
Timber Wolf's Avatar
North Florida
The blue thing under the trailer is the female side? I had not seen one like that before, and it gives me an idea. Thanks!
Old 01-08-2015, 11:52 AM   #3
Trailer: Bonair
Nova Scotia
Yes..what you see is the weatherproof cover. my original thought was to just use the old location but with the lower location the cord lays on the ground next to the trailer hence less chance of tripping..
oxygen
Shore-power connector replaces pull-out cord peterh Modifications, Alterations and Updates 72 12-18-2016 12:43 PM
Shore Power master fuse? barbflynn Problem Solving | Owners Helping Owners 4 07-25-2012 08:51 PM
76' Surfside - Does the battey charge when shore power is plugged in? dannis Problem Solving | Owners Helping Owners 2 05-26-2012 07:36 AM
A Question About Shore Power Red-Dwarf Problem Solving | Owners Helping Owners 10 03-21-2012 04:20 PM
Converter makes noise when in shore power Tezha Problem Solving | Owners Helping Owners 9 10-13-2010 02:52 PM
