beachcomber trailer - Fiberglass RV
Old 03-01-2013, 12:18 AM   #1
Trailer: beachcomber tm 15
beachcomber trailer
Hi, does anyone have any info on the tm 15 beachcomber? I would like to know if they came with brakes ? Where can parts be obtained , what is the weight?
kprpap is offline   Reply With Quote
Old 03-01-2013, 02:17 AM   #2
Carol H's Avatar
Ken, most of the small parts etc for all our trailers are used and found on many brands of trailers so you should be able to find a usable replacement for most items. For bigger items such as cabinets you would need to do a custom job. I dont know if they came with brakes if you do a Google search on this site on Beachcomber you will see lots of old posts. Looks like some had brakes some not and others have them but they dont work. I think if you go to the main page of this forum you might find a manual with more info on that in the Documents Center.
There is an old thread called 1976 Beachcomber B15 that gives you some specs - but be warned the weights given may be out of the manual as they seem way to low to me for a 15' trailer. So they may be the manufactures dry weight which means you need to add about 600/700lbs to the 1450lbs to that. A Surfside 15' which is much the same as the Beachcomber weighed ready for camping at 2120lbs total (including tongue) and a Trillium 15' weighed in at 1974lbs loaded for camping. With a full propane tank and a battery on the tongue its also a good bet the tongue weight will be more in the 160lb or higher range as well.
Old 03-01-2013, 10:43 AM   #3
beachcomber info
Thanks for the help.
beachcomber
PE | For sale 1974 beachcomber fiberglass trailer $3750 obo darcy & doc Classified Archives 2 03-21-2013 08:21 PM
Beachcomber Fiberglass Trailer - 15 Foot - 1979 - $4200 David Tilston Referrals: Molded Fiberglass Trailers 0 02-17-2012 12:56 PM
Beachcomber Trailer don o Problem Solving | Owners Helping Owners 2 05-27-2011 05:46 PM
1977 beachcomber no brakes on my trailer. Lori-Ann Problem Solving | Owners Helping Owners 6 08-13-2007 04:54 PM
Anyone else on here own a Beachcomber? asanford Problem Solving | Owners Helping Owners 0 01-01-1970 12:00 AM
