shower drain in a Biggar plugged? - Page 2 - Fiberglass RV
Old 02-08-2013, 12:27 PM   #21
Kenny Strong's Avatar
Utah
Stu and others with this problem; not associated with a broken gate valve, I have used a shop-vac to suck thing up and out rather than trying to force them forward.
Later Kenny
Kenny Strong is offline   Reply With Quote
Old 02-08-2013, 02:57 PM   #22
calindor's Avatar
Trailer: 19' 1977 BIGGAR
Originally Posted by Marinab View Post
Hi Clayton, I have some manuals for my Biggar...Oven, Furnace, Refridgerator, etc. Which one did you need? I don't know if the
appliances are the same in the Boler as the Biggar though.
Marina
Thanks Marina!
We actually have a Biggar now, but I hadn't updated the trailer type in my profile and it said Boler at the time of my post a few days back. You probably saw the thread where Gina posted pictures of the Biggar we got a couple weeks ago... that one is ours now.
Hmm.. seems that I took a photo of the french data sheet instead of the english one, so let's see how many appliances I can translate to English:
Coleman 4312 furnace (fournaise a air chaud)
Atwood G610-3 hot water tank (chauffe-eau)
Traviller 184-50 stove/oven (cuisiniere)
Tedco TW444 fridge (refrigerateur ou glaciere)
Triangle 69220-07 range hood (hotte de cuisiniere)
Voyageur 33-1 ??? maybe the propane regulator? (recipient a gaz)
Are these similar to yours?
Clayton
1977 19ft Biggar
calindor is offline   Reply With Quote
Old 08-18-2013, 07:52 PM   #23
Trailer: Biggar
Saskatchewan
Hi Stu
I also have a Biggar with the shower drain problem did you fix your drain? (MY drain valve works)
nurliart is offline   Reply With Quote
Old 09-17-2013, 11:30 PM   #24
Marinab's Avatar
Trailer: 1977 TM14 Surfside / 2007 Toyota Tundra V8 2wd
Chris, did you figure out your drain problem? If not, there is no problem with the valves. It doesn't go into the grey water holding tank, it drains straight out. you have to put a protable water tank or bucket under the opening. Do you have pics of your trailer? I would love to see yours. Thanks, Marina
Life would be a million times better if there were Pinatas strategically placed throughout the day.
Marinab is offline   Reply With Quote
biggar
Shower Drain Check Valve Baj Problem Solving | Owners Helping Owners 12 10-03-2016 02:27 PM
Shower Drain? Christi V. Plumbing | Systems and Fixtures 26 11-02-2010 10:17 PM
slow shower drain sean m Problem Solving | Owners Helping Owners 2 02-14-2010 10:29 AM
E-Z Shower Drain Valve Extension Legacy Posts Problem Solving | Owners Helping Owners 2 05-10-2003 08:03 AM
shower drain Legacy Posts Problem Solving | Owners Helping Owners 8 10-02-2002 06:28 PM
