10 inch brakes for Boler 13? - Fiberglass RV
Old 04-11-2018, 06:02 PM   #1
I am in the process of ordering a new Dexter axle and electric brakes (see attached photo) for my Boler 13. I was given a pair of 10" Dexter electric brakes and wondered if it was possible to fit them into 13" Boler rims?
I would appreciate your advice on the above.
Thanks Elvin
omache27 is offline   Reply With Quote
Old 04-11-2018, 08:05 PM   #2
The #10 torflex, 2.5K to 4K, AKA 3.5 K axle uses 10" brakes. The #9 torflex 1K to 2.2K uses 7" brakes. The spindles are different sizes so the drums would be the issue. The brakes both use a 4 bolt brake backer plate but I'm not sure if the spacing is the same. I assume you are using the #9 on the Boler. The #9 has smaller spindles. You could use the 10" brakes on a 2.5K #10 axle if that is what you want order.
Eddie
Old 04-13-2018, 12:39 PM   #3
Thanks Eddie,
I still want the #9 axle as it will give a softer ride so I'll look into whether I can put larger spindles on that axle.
Elvin
Old 05-21-2018, 11:22 PM   #4
Roy in TO's Avatar
Originally Posted by Eddie Longest View Post
The #10 torflex, 2.5K to 4K, AKA 3.5 K axle uses 10" brakes. The #9 torflex 1K to 2.2K uses 7" brakes. ...
Eddie
Originally Posted by omache27 View Post
Thanks Eddie,
Elvin
Part of the weight rating is related to how much rubber is inserted into the axle housing. There should be very little difference in ride between a #9 at 2.2K or a #10 at 2.5K. There is only a 300 Lb difference between the two.
OTOH I would expect a large difference between the ride on a 1K and 4K rubbered axles.
boler, brakes
putting 15 inch wheels on a boler??!? thenoob Problem Solving | Owners Helping Owners 8 04-27-2019 09:25 AM
3 inch lift, upgraded axle & 15 inch rims on Scamp 16 foot BrewskiDV Modifications, Alterations and Updates 12 05-01-2016 11:21 PM
14 inch tires on S13? adimiro Care and Feeding of Molded Fiberglass Trailers 13 11-04-2011 07:51 AM
Dexter 10X2.25 inch brakes. Perry J Care and Feeding of Molded Fiberglass Trailers 1 07-16-2010 08:19 AM
brakes or no brakes Penney H. & Mike E. Towing, Hitching, Axles and Running Gear 17 08-13-2007 02:35 PM
